Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
Our washing is always damp after it's been "Tumble Dried"! I note that some washer dryers have a long tube coming out of back of machine and through he wall of the house. Is our Hotpoint Aquarius 1200 WD62 meant to have one? It hasn't - the person who installed the machine did not fit one nor mention the need for one. I just wondered where all the condensation goes from the drying process. Is this the root of the problem? Please advise.
  • 2 more comments
  • Cajun Aid Aug 14, 2007
    Okay, thanks for the assistance which was useful.
    Can you offer any solutions to eradicate the problem?
    We do run the machine for quite a while before removing the clothes, but they remain somewhat damp.
    Is this to be expected, or should they be bone dry?
  • Cajun Aid Aug 16, 2007
    Thanks Gittos73. Will try your advice and see what happens. Thanks.
  • Cajun Aid Nov 11, 2007
    I will try this later.Thanks.
  • clairewake Oct 16, 2008
    I have just taken the back of the unit apart but where do I look to see if there is a blockage?
When you open the door at the end of the dry time, is there lots of steam???
if so it can be one of 2 probs, the 1st is check the condensor unit which is on the back of the drum/tank, its a cream/blue colour and will be full of fluff lint. clean this out and retry. if that does not cure it will prob be the 3 way inlet valve sticking causing the machine not to condence
Posted on Nov 08, 2007
    Novelist:
    Champion:
  • 244 Answers
No the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Posted on Aug 14, 2007
  • peter gittos
    peter gittos Aug 14, 2007
    no your items should be dry if u take of your lidu will see your heater on the top there will be 2 thermostats replace these only about £10 to replace and this should solve the dampness but u do have to take out half of your washing for it to dry proper try this b4 replacing your stats u might find that this will help alot if your not already doing this m8
SOURCE:
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Programing a wash without drying
I had the dial on the wrong setting sorry to be a pain
Julie
Dec 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
548 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
