Question about Ricoh Aficio 1515 All-In-One Laser Printer
Scanning software issue
I need to be able to scan all my documents and make them into 1 folder or file
  • Anonymous Mar 23, 2014
    I need to change the address that the documents I scan go to. I have changed my computer and need to update the address
    I need to change the destination folder for my scanned documents as I have changed my computer
  • 37 Answers
If you go to scan settings under user tools you will see that you can set it to a multipage pdf or multi page jpeg tiff , or what ever , so if you scan 20 pages it will create 1 file and it would contain your 20 pages
Posted on Nov 16, 2007
SOURCE:
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
Where do I find a picture I just scanned and want to attach to an email
Hi Teresa, A bit more information is required to help provide a solution such as what software or scanner are you using. What operating system you are using and any additional details you think would be helpful.
The common places to look is check in your My Documents or My Pictures folders for the scanned images or any special folders that are created by your scanning software.
You could also perform a file search in a folder for files that have been edited or created on the date you scanned to locate the source folder.
Otherwise, open your scanning software and check the Preferences (probably Edit > Preferences) for the default location where items are saved when they are scanned.
If all else fails, scan it again and do a 'Save As' operation to place it on the desktop of another folder that you are familiar with so you may find it in the future.
Regards,
Adam
Oct 20, 2013 | Computers & Internet
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
I don't know how to scan and save in forlder, to be able to send them through e-mail. The printer was given to me without the manuel
The printer was given without a manual because Hp has all of a sudden decided to go green.
anyway if you look on your desktop you will see and icon called the hp solution centre.
Bear in mind that you will only see this software once you have installed the software with the disc that came to you.
Place a document on the scanner glass of your printer face down.
Open the solution centre and you'll have a button called scan picture or scan document click on whichever you want and then select the type of file you want the picture or document scanned as.
once done click on the ok button and the scanning will start.
If you need to scan another picture click on finish and the folder will popup where the scanned file is saved.
If you need to scan another picture or document into the same file at the top you have an option on the scanning window saying add another page click on that, once all the pics or documents are done click on finish and the folder to where the scanned files are saved will open up.
by default the scanning path for WINDOWS XP is in my documents under the folder called my scans.
in WINDOWS VISTA AND WINDOWS 7THE SCANNING PATH IS DOCUMENTS AND THEN A FOLDER CALLED MY SCANS
tell ya what copy and paste the links below and follow the steps and would appreciate four stars if you think I am helpful :)
FOR WINDOWS THE LINK IS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02459304&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For Mac OS the link is
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01910186&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 03, 2011 | HP OfficeJet J4580 All-In-One Laser...
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Photosmart c7180 unable to scan since Windows 7 computer
go to following location and try to scan and tell me if it is scanning fine or same issue.
c:\program files\hp\digital imaging\bin in bin folder locate following files. /* in 64bit operating system inspite of program files look into programe files(x86).*/
1.> hpqscnvw
2.> hpqscnappi
3.> hpqdstcp.
4.> hpqgrpky.
double click on any of these it will start scanning.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
I'm trying to use the scanner to scan some documents and store it in a folder in the computer. Can you help me with this? Ray
Your software will usually ask where you want to store the document once it's scanned. A lot of software is intuative enough to guide you through each step.
Aug 19, 2009 | Office Equipment & Supplies
Problem scanning to PC.
Scanner needs:
1- a second ethernet cable and its own IP address.
IP address should be similar to the printer.
2- a folder in PC ie: C:\SCANS. This folder should be input in scanner web page (entered in the address bar of a browser ie 192.168.1.10)
3- Install the file utility resident program in PC.
Feb 05, 2009 | Kyocera Copystar CS-5035 Copier
Ricoh Aficio 1515 All-In-One Laser Printer Logo
349 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
