Question about Olympus Camedia D-540 Zoom Digital Camera
Remove protected pictures
I have several pictures that i can not get rid of is there a way to undo the protected pictures process, thanks for any info.
    President:
  • 1,114 Answers
Refer to page 82 of your manual. You can download the manual from the link below: http://www.olympusamerica.com/files/D540ReferenceManual.pdf You need to select the protect "off" in the playback menu. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
SOURCE:
How do i get rid of my write protection on on the sd card
Wecome to Fixya. Memory card has a slide switch on the side or along the edges, you just have to slide it to get rid of the write protection on your memory card. Just remember that if the position nearest on the contacts is already removed the write protection on the SD card.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cameras
When I turn my digital camera on it says card is protected I can view the pictures in there but it wont let me take any photos how can I use my camera and get rid of this
Please remove the memory card from camera
and there is a small sliding switch at one side slide that to unlock
Thanks
Apr 16, 2011 | Fuji Cameras
My MicroSD card is write protected and i need to remove and add MP3s how do i undo write protection?
hello flip the switch for write protection picture here http://static.commentcamarche.net/en.kioskea.net/faq/images/0-hXBUyBSB-t555-1122-callout-s-.png
Nov 04, 2010 | PNY 2GB microSD Memory Card
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Just paid for 2010. Cannot get rid of screen that states "trying to remove old product". Has been showing for several hrs. What are my options to get rid of the screen?
start task mngr ( CNTRL+ALT+DEL) then find it under applications or processes and end the task-then remove it under control panel>add-remove programs
Mar 20, 2010 | Dell Dimension 2400 PC Desktop
How to take protection off of pictures on camera so I can cancel.
You should do the same process like above to unprotect the images. Trying to delete is wrong.
If this helpful please vote with high rank Marie. Thank you.
Apr 29, 2009 | Sanyo VPC-E760 Digital Camera
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Dec 19, 2008 | Olympus FE-220 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Protection
The tape is write protected, remove the tape and make sure the green strip is set to REC as opposed to SAVE.
Jun 05, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Olympus Camedia D-540 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
