Question about Symbol MC1000 Barcode Scanner
Auto Enter is False
How can enable auto enter for Symbol MC 1000 device?
  • 3 Answers
Do you mean so that it will automatically input 'enter' after each scan
If so, this can be solved by ediitng the registry. You can do so as follows:
Download the enter file (this is a sendspace link, so it will not be up for very long).
Copy the file to the "Application" folder on the MC1000 and then do a cold boot and test.
I'm afraid I don't really understand how the reg has been editied in this file, otherwise I would post more detailed instructions rather than asking you to trust a file from an unknown person. But this fix was given to me by someone ore knowledgeable than me, and it has okay on my scanner!
Posted on Feb 28, 2008
  • Webbreader Feb 28, 2008
    Further digging reveals advice about this on the Symbol website.
    See their guide on how to create the reg file (saves you from having to trust my file).
How do i get my scanner to do "enter" without
Hello Severiano,
this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document. https://docs.symbol.com/attachments/ADC-01244.doc
Aug 02, 2011 | Symbol LS2208 Handheld
80710723 error
A PS3 Error 80710723 signifies a network/router error. Try going to SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > (if wired, choose path 1. if wireless, choose path 2.)
1. WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
2. WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
Jun 15, 2011 | Sony PlayStation 3 40GB System
Error code 80710723
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
Hi sir turbo c is not full screen in windows 7 please give me a soluaction
trans.gif?cver=2.13.0068.4 0 follow
u can edite ur dosbox-0.74 conf file.
u have to find conf file.
path start->all progarme->doxbox->option
it not include it .
run dosbox->see where the conf file it will dispaly.
find it.
u edite ur conf file.
example see my confi file.
chanadana nalin cooaray
chandanaworld@gmail.com
0715372331
exam-my confi file
# This is the configurationfile for DOSBox 0.74. (Please use the latest version of DOSBox)
# Lines starting with a # are commentlines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1366x768).
# Using your monitor's native resolution with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
//# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=ture
fulldouble=ture
fullresolution=original
windowresolution=original
output=surface
autolock=false
sensitivity=100
waitonerror=true# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
# (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombo.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# See the README/Manual for more details.
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
# Possible values: auto, cms, opl2, dualopl2, opl3, none.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
mount d c: urbo
d:
cd tc
cd bin
tc.exe
Sep 03, 2010 | Microsoft Select Application Center...
I have an error code 8013031B is there a fix?
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS >
Mar 03, 2010 | Sony PlayStation® 3 (60 GB) Console
Dns error 80710102
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
May 07, 2009 | Sony PlayStation 3 40GB System
Wireless connection
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X hope this helps...rate me please, if it does...thanks
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Need unlock code for my samsung vodafone
Try this it work for me
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam!
I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this!
I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI).
Check Versions of h/w s/w f/w:
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
Locks:
*#7465625# = Check Locks
*7465625*638*Code# = Enables Network Lock
#7465625*638*Code# = Disables Network Lock
*7465625*782*Code# = Enables Subset Lock
#7465625*782*Code# = Disables Subset Lock
*7465625*77*Code# = Enables SP Lock
#7465625*77*Code# = Disables SP Lock
*7465625*27*Code# = Enables CP Lock
#7465625*27*Code# = Disables CP Lock
*7465625*746*Code# = Enables SIM Lock
#7465625*746*Code# = Disables SIM Lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network Lock ON
#7465625*28638# = Auto Network Lock OFF
*7465625*28782# = Auto Subset Lock ON
#7465625*28782# = Auto Subset Lock OFF
*7465625*2877# = Auto SP Lock ON
#7465625*2877# = Auto SP Lock OFF
*7465625*2827# = Auto CP Lock ON
#7465625*2827# = Auto CP Lock OFF
*7465625*28746# = Auto SIM Lock ON
#7465625*28746# = Auto SIM Lock OFF
May 03, 2008 | Lands Phones
How to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Sep 03, 2007 | Panasonic KX-T7633 Corded Phone
Symbol MC1000 Barcode Scanner Logo
300 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
