FixYa.com
Tags:
Emerson EWC20D4 Combo
Blows fuse (by 2 users)
posted by dwitchel on Aug 14, 2007
Has a dead short blows fuse everytime.
Comment by dwitchel, posted on Aug 15, 2007
If I disconect the Degauss wire it will play and not blow the fuse.
Comment by dwitchel, posted on Aug 16, 2007
I can not find a thermistor on this set. Do you have a # for this part?
Comment by dwitchel, posted on Aug 21, 2007
Replaced Thermistor,hard to locate.
Thank You For Your Help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by 01ed, posted on Jan 09, 2008
replaced fuse with known good. Blows at power up
Best Solution
FixYa! (100)
MikeNJ1964
Rank:Guru Guru
Rating: 89%, 577 votes
If you disconnect the degaussing coil and the set plays fine, it means one of 2 things is wrong. The degaussing thermistor could be shorted internally. I have seen this happen a few times on those degaussing thermistors that are in the little black boxes with 3 legs. Those boxes actually have 2 thermistors in them, one to do the actual degaussing and another connected directly across the AC to act as a heater for the degaussing thermistor. One of those thermistors could have "flashed over", which would blow the fuse the instant the set it turned on. The only other thing would be the wrong size main fuse. Without a degaussing coil the set probably draws about one amp, but the surge at turn-on with a degaussing coil could be as high as 4 amps. If you have the correct fuse installed and it blows at turn-on, replace the degaussing thermistor.
Comment by MikeNJ1964, posted on Aug 17, 2007
I do not know the part number for the degaussing thermistor in that set, but it is easy to find. The degaussing coil is wrapped around the picture tube and has the 2-conductor plug that plugs into the jack on the main board, very close to where the AC power cord connects to the same board. The degaussing thermistor is usually right next to that jack. Sometimes it looks like a silver coin with wires attached to the sides, sometimes it is dipped in a colored coating, and sometimes it is inside a little box. Follow the traces for the degaussing coil's jack, one will be connected to the thermistor. The thermistor may be labeled something like "TH001" on the board, but I have also seen them labeled with an "R". Let me know if you still have trouble finding it.
Rating Locked! (?) dwitchel has rated this solution as FixYa!
Solution #2
FixYa! (100)
troylove11
Rank:Wiz Wiz
Rating: 84%, 1042 votes
Power supply definately. Check for short in bridge retifier. Any Diodes short or regulator bad. start from power cord coming in and check all. Could be anything. Use a meter on continuity and just check across doides when you check and it keeps beeping reverse leads and see if it still beeps constant. That maybe your problem.
Solution #3
posted on Jul 24, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If not could be smoothing cap on the mains side, aswell as the bridge, fuse also
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these TV Combos problems?
TV Combos
2 week old dvd/tv makes loud...
week old dvd/tv combo second... Answer This...
TV Combos
Timer
the timer on my tv is on how do... Answer This...
TV Combos
blue screen
I'm getting nothing but the... Answer This...
Thermister Blown / Fuse
Did some reading on other post... Answer This...
DVD
Do you know where to get a DVD... Answer This...
Repair Service
Find TV Combo Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
