Question about Tappan TGF363 Gas Kitchen Range
Tappan Gas stove
I have older model Tappan gas stove with pilot light. I found the adjustment for the burner pilot light but I did not find adjustment for Oven burner pilot. I can see my oven pilot is weak. Oven control knob had LP, OFF and Nat option. I clean the tube and valve but still not much help.
  • 5 more comments
  • kamlesh Aug 20, 2007
    it worked
  • Anonymous Apr 04, 2008
    I have a Tappan stove and I cannot seem to figure out how to re-light my pilot light for the OVEN. I did re-light the top 4 burners and they've working just fine. SERIAL #80164Q41 & MODEL# 30-2139-23/02. It says that I have an INTERMITTENT IGNITION DEVISE on this model. I'm beside myself trying to re-light this oven. HELP! Looking way in the back of the in the bottom (broiler area) - I cann't figure out which gizmo is the pilot light. A diagram from you indicating where it is, what it is and how to go about lighting it. Thank You!
  • Anonymous Mar 21, 2014
    I have a new Wolf Oven Model # GR366-LP and the indicator light above the thermostat blinks consistently.... even when the oven is off ?
    Jay
  • Anonymous Mar 22, 2014
    Tappan mod #32-1019-00/04 Serl #VF03605055 I have changed all parts just need to adjust flme in oven
  • Anonymous Mar 24, 2014
    The oven control knob is missing from my propane stove.
    Where can I find a knob for oven adjustment for a 20 inch hardwick propane stove.
  • Anonymous Mar 27, 2014
    pilot lights but burner won't light
    President:
  • 331 Answers
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
SOURCE:
I just moved into a condo I am renting and the Tappan gas oven/stove stays hot when it is not even on. The part that is hot is the top between the burners. Is that normal?
Probably the pilot light. You should be able to lift the top of the stove for cleaning ... try lifting it ... to see and verify for yourself this is the case.
This is very typical of a stove fired by a pilot light.
Thanks for your question at FixYa.com
If you found this helpful, the courtesy of a positive vote will be appreciated. Thank you.
Sep 19, 2010 | Tappan TGF320 Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
1,636 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
