Question about Logitech X-230 Computer Speakers
Blown speakers Hallo, I have a problem with my logitech x-230 speakers. I bought the speakers in USA which works with 110V and without realising that I need a converter I just plugged the speakers directly and as a result I think I might have blown it. Can you tell me if there is a possible fix for it? Regards
Did you manage to repair it ? i have the same problem
Posted on Feb 14, 2008
    Genius:
  • 2,985 Answers
No fix- buy new ones
Posted on Aug 14, 2007
SOURCE:
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
What is the specific power transformer (internal) i need to switch my logitech 230 speakers from 220v to 110v?
If the speakers are wanting 220V, will they work, at a diminished level, if you only supply 110V ?
Otherwise, you need a "step-up" transformer, which takes 110V input, and produces 220V as output.
Do the speakers have a "110V/220V" switch on them????
Apr 05, 2010 | Logitech X-230 Computer Speakers
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Jul 18, 2009 | Logitech X-230 Computer Speakers
Suspected blown fuse somewhere but no sign of it
Am sure that the internal transformer is gone, You would have powered your speaker with a step up/step down transformer, you need to see a technician around you that can help you out, you need to replace a 220V-230V transformer in the speaker since your country requires that.
Jowinson
Jun 20, 2008 | Logitech X-540 Computer Speakers
X-230 Speakers Hum
bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Jan 16, 2008 | Logitech X-230 Computer Speakers
No sound out of spekers... or sub.
check for the manual online, also make sure you have the driver for the speakers....
Nov 10, 2007 | Logitech X-230 Computer Speakers
Logitech x 230 speakers "dead"
Razor Your correct, you will have to open it up however which may void a warranty depending on how long you have had it. It is possible the converter went bad, this happens in these. If this is the case Logitech is really good on replacement and price{ if you even have to pay} The link below is a test link you can try and also a Logitech forum with Logy employees that are really good with help and support. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2913&p_created=1125714076 Hope this helps.
Sep 19, 2007 | Logitech X-230 Computer Speakers
Blown Subwoofer
Hi , you will have to open the box and check for any fuses along the power input line, replace them if any and try it out but i strongly believe what happened there is that you fried the power supply in your subwoofer , there is no easy fix to this , you will need to replace the transformer and possibly check to see if the rectification circuit is damaged too, and the amplifier too. Good luck
Mar 21, 2007 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
277 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
