Question about SanDisk Sansa c150 MP3 Player
MY Sandisk c150 keeps blinking when turned on.
I only got my sandisk c150 over a month. Everything was fine until the other morning i put it on and it just keeps showing the sandisk logo which dims periodically. The only thing i can remember was the night before i pulled it out of the pc with out disconnecting the usb in windows. Why should that be the result? Please help, i really need this device to work/replaced because i need to use it's 2gb capacity and voice recording feature the most. Help Needed.
    Genius:
  • 2,985 Answers
You have probably corrupted it. Plug it back into the computer- reformat if you must and do it properly as you know you should. You may wind up buying another
Posted on Aug 14, 2007
SOURCE:
My Sandisk Sansa C150 Menu is Frozen. How do I unfreeze it? The same song keeps playing over and over. I can't turn the devivce off. Except if I take the battery out
You need to reset your player to default settings...
There is a reset method - check your user manual, or follow the below link -
http://www.retrevo.com/support/Sandisk-c150---2GB-MP3-Players-manual/id/393dj987/t/2/
Good Luck!!
Thanks
Jul 18, 2009 | SanDisk Sansa c150 MP3 Player
Sansa c150
Wait till it runs out of power then charge it. It should charge up normally.
Jul 07, 2009 | SanDisk Sansa c150 MP3 Player
Reset
Just go connect it to your pc.then go to my computer and then right click on the drive which belongs to your sandisk sansa c150(1gb) 2gb mp3 player and select the option format.
Thats all.
May 07, 2009 | SanDisk Sansa c150 MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Sansa sandisk c150 mp3 player
Try to reset your device by holding the power button down for 15-20 seconds or until it resets....If that doesnt help you get the latest firmware upgrade for your device...that should solve the problems you are having...
Nov 28, 2007 | SanDisk Sansa c150 MP3 Player
My Sandisk c150 is frozen and I've tried to turn it off and push the Hold button then turn it on again, but all that comes up is a symbol of a lock. Please HELP!
In this case on the Mp3 player itself u will see a Hold/Unphold slide switch just slide that switch to the opposite direction and that will fix the problem
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
HELP NEEDED ASAP!!
  • nevermind.
  • i just figured out if you format the thing over and over it's good as new.!
Jul 11, 2007 | SanDisk Sansa c150 MP3 Player
Sansa SanDisk c150 won't turn on!
My Sansa also failed to turn on. But what happened to me was that I unplugged the USB while it's connecting. After that I cannot sync with my computer anymore, so I tried turning it off and on couple times and at the end the whole thing won't turn on anymore. I talked to the SanDisk tech. You can try what he told me: take out the battery; press and hold the power button for 45 sec (this will drain the power in the capacitor...they call it "soft reset"); then put the battery back in and try to turn on the mp3 player. That didn't work for me. I just bought this a month ago so i guess because of the warranty, they will send me a brand new one. I hope this help.
Apr 11, 2007 | SanDisk Sansa c150 MP3 Player
SanDisk c150
do you have WMP10 installed? I couldn't transfer songs, although my computer recognised the player, until I installed it, I had an older version of WMP. and check in settings/power that it's set to auto power off on the player. the 'start updater browserDB' is normal after synching the player.
Dec 25, 2006 | SanDisk Sansa c150 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
