Question about Nikon Coolpix 5600 Digital Camera
Zoom every time i switch on my camera it zooms in of its own accord and i cannot zoom out again.
    Genius:
  • 2,985 Answers
Are you saying the lens is out before you switch it on? Please clarify
Posted on Aug 16, 2007
SOURCE:
The zoom on the sb600 wont adjust accordingly to the zoom of my lens
Three things come to mind.
First, make sure that you are in fully automatic mode - easily done by reset (holding down "Mode" and "On/Off" at the same time. If you hit the "zoom" button it takes it out of automatic zoom and cycles through manual zoom settings until you get to auto again.
Second - make sure the camera is in an auto mode - manual mode could stop it from zooming.
Third - make sure that you don't have the diffuser pulled down. That can keep it from zooming also.
Mar 30, 2010 | Nikon Speedlight SB-600 TTL Flash
Zoom error
reset camera but it would appear that the lens is not functioning properly and would need repair
Sep 06, 2008 | Olympus SP-550 UZ Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Sony DSC-w50 zoom not working
switch on when the lense extends take the end of it and gently twist and pull the lense you may hear it click be gentle do not force it then switch off and on again and this will solve the problem 98% of the time.
Jan 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Zoom Lens
Hello, DCR-PC7E in order to repair this error you should replace the switch block part number: 147383111. Best regards, Arpi
Apr 19, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Nikon Coolpix 5600 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
