Question about Epson Stylus CX6600 All-In-One InkJet Printer
Broken printing head of CX6600
I disassembled the printing head of my CX6600 and now I have problems to put it back together again. One small metal plate with holes and bendings is very problematic. If possible can someone send the picture of the printing head or tell how to fix the head.
  • Epson Master
  • 705 Answers
Get in touch with the good people at http://www.TheServiceManualShop.com and get a service manual from them. This should have all the info you require to re-assemble the head.
Posted on Aug 14, 2007
Double imaging
hi.
1 put a small amount of light on on the bale bar (the bar the print head slides on) and then do a head clean. If this doesn't clear the problem, try doing a print head alignment, (see my previous fix) hope this helps
Apr 02, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cx6600
If you mean the printer goes through the motions of printing but fails to actualy put any ink on the paper then see my previous post about intensive head cleaning.
http://www.fixya.com/support/t138226-printer_not_printing
If the head cleaning has little or no effect then you may need this following rescue kit to resolve a know problem with many of the CX range:
http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical
May 18, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 takes up to 2 minutes from when Print pressed to Print
Hey Zitta, Check to see that you have the latest version of the Printer Driver installed on your new drive. Go to www.epson.com and you should find your way through to your local site. Then head for the support area and look for the driver download.
Mar 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
186 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
