Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
MONITOR GOES OFF AFTER WORKING FOR SOME TIME.
The monitor goes off after working for some time. Then even if we reboot it wont work for some time. After some time it works as normal.
  • bandonpaul Dec 01, 2007
    More and more frequently, when I leave the monitor on and do not use the computer for 15 minutes or more the monitor does not come back on. Instead a floating memo box that states "Not optimum (screen size)..."
    I have been disconnecting the monitor for 10 to 30 minutes, after which it usually comes on and operates OK. Sometimes I have to repeat this process.
    '[email protected]'
  • ianpearl47 Jul 23, 2008
    Monitor goes off after 20mins or so of use and a floating box appears with the message "not in optimum mode" displayed. The only temporary cure is to turn off at power supply and re-boot after approx 30mins.
  • 63 Answers
Sounds as if something within the monitor is overheating or a component (maybe a capacitor) is going bad. Either way, if it is under warranty, I believe Samsung has a 3yr warranty, it should be repaired by a professional.
Posted on Aug 14, 2007
SOURCE:
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
Screen randomly goes into powersave mode????? For no reason into switches off & i have to reboot to get it working agan???? Help!
well you can increase the time limit of your powersaver setting or you can even disble it. if this doesnot work then try to get it repaired
Aug 01, 2009 | LG L1718S (Silver) LCD Monitor
Monitor goes to sleep after 30 minutes vl1919
Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor went to sleep and won't wake up
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor or pcu problem
It appears that your graphics card is defective. If the monitor works on your laptop and reinserting the graphics card did not help, I would suspect the card itself.
Aug 19, 2008 | Acer AL1716 17" LCD Monitor
Hp laptop wont restart
please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Apr 05, 2008 | Computers & Internet
Acer AL1711 17" LCD Monitor goes blank without warning
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
Jan 26, 2008 | Acer AL1711 17" LCD Monitor
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
179 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
