Question about Konica Minolta DiMAGE G600 Digital Camera
Error code S0042, DIMAGE G600
I HAVE A DIMAGE 600 WHICH DO NOT COMPLETELY OPEN OR CLOSE. IT KEEP DISPLAYING ERROR SYSTEM S0042. WHAT THIS MEAN AND HOW CAN BE FIX? I WILL APRECIATE YOUR HELP, THANKS.
  • 4 more comments
  • Anonymous Dec 06, 2007
    Camera will not open or close. error message S0042 is displayed
  • Anonymous Mar 20, 2008
    When opening the lens cover,screen switches on but is blurred,then error code S0042 appears and LCD switches itself off
  • shortwinded Sep 21, 2008
    I have the exact same problem with the lens stuck at halfway in and out.  The proposed twisting didn't work.  The mechanism doesn't really seem to twist and you can't get a good grip anyway.  Any other thoughts.
    - Dissappointed
  • damdoum Nov 09, 2008
    I have the same problrm,, the camera slipped from me and the lense is stucked and wont move neither open nor close, I am from Jordan/ middle east
  • Anonymous Mar 13, 2009
    Same problem
  • zoz58 May 16, 2009
    how do i put this right error S004 THANKS
I had this problem with my 600. I noticed that the end, center, part of the focusing mechanism was slightly out of alignment. (The part that usually sticks out furthest.) Once I straightened that piece, it was able to retract and the camera could be closed. Look at the focusing mechanism from all sides to make sure it is straight. The part was very slightly off, but enough to cause the error. My camera has been working fine since.
Posted on Nov 11, 2008
  • 641 Answers
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Aug 14, 2007
SOURCE:
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Installed ROM into a working HP LJ 4200n, now it does not work, it displays errors "rear door jam" and "cover open".
Check that ALL of the covers / doors are closed completely. If they are not closed completely and securely, the safety switch will not close and the printer will not work - and displays the error. Since the error is "rear door jam" check the back of the printer...a door panel may have popped open while you were working on installing the memory.
Dec 01, 2009 | Office Equipment & Supplies
My camera lens wont close and says system error s0042 konica revio kd-310z
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 08, 2009 | Konica Revio KD-310Z Digital Camera
Sustem Error S0042
Todd, What you can do is to powerit on and try to pull the lens out manually. Do not use too much strength or rotate. But try it a few times and the lens casing may stop touching the camera body. Once the lens comes out fully then the camera will boot up and work.
Sep 12, 2009 | Konica Minolta DiMAGE G600 Digital Camera
Cam cannot mak any pictures. ''Error 2''
I have already answer to this problem. To try on solve it you need to remove the metal front cover and check if the socket of the large flat coming fron the back of camera is complete inserted on his shell, or if you damage the cable because the camera drop down
Apr 11, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 24, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Konica Minolta DiMAGE G600 Digital Camera Logo
631 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
