My dishwasher is an Ariston Advantage AF250: I have been told that internally its the same as a Hotpoint DF55. It intermittently leaks water onto the floor from the front at its base during use. At one time it ruined the motor which I had rewound and at the same time I made a new polystyrene float for the base pan overflow switch. All was well for months, but now its leaking again. I have blown through the tubes from the drain filter well to the pressure sensitive switch, but all to no avail. It will, no doubt, be something simple and that's why I don't want to scrap it. Meanwhile the enemy is constantly on my case.
hi there, dishwasher leaking might be due to either of these causes, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
* Lower rack *Spray arm * Spray arm support * Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
sometimes the upper arm on my hotpoint dishwasher doesnt spin and the dishes come out dirty. There...
(More)
sometimes the upper arm on my hotpoint dishwasher doesnt spin and the dishes come out dirty. There are no blockages and I have tried washing it out with dishwasher cleaner. it doesnt always happen, just sometimes.
Technika problem. 1) The door is out of alignment with the lsft side being about 1/2" further...
(More)
Technika problem. 1) The door is out of alignment with the lsft side being about 1/2" further out when door closed. Water is escaping on to floor. 2) Loud whooshing noises are heard late in the cycle, almost explosive. Help!
