Smartpool Robo Kleen Logo
A
Anonymous Posted on May 18, 2013
Robo kleen plus not working - Smartpool Robo Kleen
5 Related Answers
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Aug 17, 2009
SOURCE: Robo Kleen moves but does not clean
If you can, connect it to the back wash of your pool fiter pump. Just for a few secondds that usually works well.
Anonymous
  • 52 Answers
  • Posted on Jul 10, 2010
SOURCE: My Robo kleen stop working at the end of last
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
The Pool Tech
mahoskic
  • Posted on Aug 06, 2010
SOURCE: My Robo Kleen motor is running but the wheels do
There is a plastic gear in the drive motor that has a pin that goes through it and the drive shaft, this pin actually wears a slot in it from going back and forth and stops driving the unit.
You can probably hear the driver motor cycling forward and reverse.
i have photos of a modification to fix this
Anonymous
  • 640 Answers
  • Posted on Oct 07, 2010
SOURCE: Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Anonymous
  • 155 Answers
  • Posted on May 01, 2011
SOURCE: We need a motor for
First remove the top vent cover (4 screws) and check to make sure the impeller can rotate.. excess debris can prevent it from turning.
I am not aware there is more than one motor on this unit. It should be a single 24Volt motor.
You can contact the mfg at Smart Pool (Maytronics)
email - mailto:[email protected]
But I don't see spare parts listed anywhere.
Local Dealer locator
http://maytronicsus.com/en-us/where_to_buy/store-locator/
Lastly.. you may be able to locate a motor once you have determined this one is indeed bad.. at a local electric motor shop. They can test it.. see if it's repairable or replaceable.
Wish I could help more than this.
Best of Luck
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
My robo kleen is brand new and from day one, it just rocks back and forth. It moves forward about 1 foot and then back about 1 foot.
Sounds like water in the motor . had the same problem and after drying out it worked for a week then the same problem
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
2answers
Top Smartpool Pool & Spa Experts
Thomas Perkins
Thomas Perkins
David Spradling
David Spradling
Jay Finke
Jay Finke
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
