Question about Nokia 3230 Cellular Phone
Nokia 3230 USB bot working
Whenever I connect my phone to PC using Data cable it just says "USB Device not recognized" My pC is running the most updates Nokia PC Suite, the cable is ok coz it works well with other phone same model with same PC,
  • cdoublen Aug 29, 2007
    No it doesn't work. I even tried on a diffrent PC it did not work either. Possible the Phone has some problem with USB connection port. Is it replaceable?
  • Anonymous Mar 15, 2014
    i was updating software using ovi suite suddenly cable ejected in between after that i am not able to use the phn i connect it bt it show usb unrecganized devive so what shout i do now
Try to download nokia 3230 pc suite again, but first delete the one that you have on your computer completely before installing the new one
Posted on Aug 18, 2007
    Sergeant:
  • 452 Answers
If you are getting the msg like "USB Device not recognized" that means your cable drivers are not installed properly..you have to install the drivers again,you must have got the PC suite cd you have to reinstall the software through that than try if doesnot works work than you cabel may be faulty you need to cahnge that ..but try the reinstallation first it shoiule work for you
Posted on Oct 17, 2007
SOURCE:
Whenever i m connecting the cell phone(nokia 3110 c) with the laptop via USB cable the laptop shows me message that DRIVER missing. i want to use the data cable for net connection. pls let me konow from...
Good Day,
For your driver need, you may just install Nokia PC Suite, where it installs the driver and other necessary software, including the software needed for you to use the phone as an internet device.
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Ovi_Suite_webinstaller_ALL.exe
just go to that link, install the software, and you are set. Please do not connect the USB data cable to the PC yet, until the software installation is finished. After all has been installed just plug the USB data cable in the PC and the phone, and follow the instructions on-screen.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia 3110 Cellular Phone
Communicate with computer (PC).
Hi, in order to connect the Nokia 3230 to the Computer, please download and install the Nokia Ovi Suite in the Computer, then connect through USB Data Cable which can be purchased in any Nokia Showroom or Mobile Shop.
Download Nokia Ovi Suite from the below link:
http://europe.nokia.com/support/download-software/nokia-suites-for-your-pc
You can also connect the Nokia 3230 to Computer using Bluetooth feature if you purchase the USB Bluetooth Dongle for the computer.
May 03, 2011 | Nokia 3230
I have Nokia N 72. whenever I connect with cable to USB port it popups a massage "USB device Not recognised". Before Few Months , it was working properly. and other mobiles and USB devices are...
sir plz install the n72 pc suit to the computer.and then connect the data cable from phone to the pc to transfer the files [or] change the data cable for proper connectivity from phone to the pc.................
Dec 07, 2010 | Nokia N72 Cellular Phone
Nokia 3110 classic usb device malfunctioned
Please try connecting your phone to a different USB port other than the one which you use normally.
If the issue is the same then try connecting it to another PC if you still face the problem then it is a hardware issue.Either your phone or the USB cable is gone bad.So replace the USB cable first with a new one and then try connecting.If the issue is till the same then it is your phone and you will have to get it repaired or get it replaced if it is under warranty.
Feb 10, 2009 | Nokia 3230
When i connect nokia6300 using a data cable computer says that device not recognized" please suggest a solution. I had used standard usb cable, the driver is properly installed. Recently this problem...
this may due to the problem with your data cable or it may occur for some pc's.try to check it with other cable or try to use it on other pc .thank you
Nov 22, 2008 | Nokia 6300 Cellular Phone
Nokia3230 USB modem connection to pc for use airtel live
For using Nokia 3230 as USB modem you need Nokia PC Suite and DKU-2 cable.
Download Nokia PC Suite from here:
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
1. Install Nokia PC Suite
2. Run PC Suite
3. Connect the phone to PC with DKU-2 cable
4. Wait for a while, you will see drivers are installing.
5. After driver installation your phone is connected to PC Suite.
6. Now click "connect to the internet button", a new window will open
7. Go to settings, next and go to "select your network operator from the list" and select your exact operator there
8. And click finish
Now your is connected to internet.
If you don't have the cable you can also connect the phone to PC via IrDa or Bluetooth if your phone has those connecting devices.
May 20, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 phone software update
I want to download nokia 3230 software updater. plezzzzz help me
Aug 08, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
197 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
