Question about InFocus LP 600 Multimedia Projector
Lp600 went dead
Unit went dead, fuse ok, stand-by lamp not on, display shows nothing.
  • 8 more comments
  • der_tankwart Nov 26, 2007
    Hello
    I have the same problem. Where i can found the fuse?
  • hhgurl Dec 21, 2007
    My infocus lp600 projector went dead while I was using it. Same symptoms, no standby light, doesn't turn on, absolutely nothing.
    I would like to try and find a SF bay area shop that can even give me an estimate of how much it would cost to fix it. Sending back to mfg would not be cost effective and almost as much as getting a new one (but less expensive model).
  • sethwh Feb 22, 2008
    We have an LP600 at work that does not power on. Is it worth it to replace the fuse or follow the solution below relating to condensor replacements?
  • sabrexx Mar 11, 2008
    I'm having the same problem with a Lp600; where did you find the fuse?
  • Anonymous Apr 16, 2008
    Same problem, left unit in standby mode for over 2 years. This solution worked for me. Each capacitor was a little more than a dollar at a local electrical parts store. I used a 15w soldering iron w/ a very fine tip because the solders are very small. This is only the third time I've used a soldering iron. Take your time. Hardest part is desoldering the old capacitors. google desoldering for hints. Thanks - Great site
    otto
  • Anonymous Apr 29, 2008
    Coworkers carelessly tripped the breaker, while the projector was on. Now it's completely dead, no power light or anything else
  • Anonymous Jun 11, 2008
    no power
  • GGarcia21 Jul 09, 2008
    I would like to know where the caps are are so I can replace them. Thanks Gabriel
    gaby_prez@christforlifecmm.com
  • mapella Jul 29, 2008
    I have the same problem, and I am trying to replace the caps, as per the comments posted in the forum, but I am in doubt about which really are the concerned ones for replacement. Any indication will be useful for that. I have dissassemble the unit, and fuse is OK.
  • jmr1937 Apr 09, 2009
    It does not power on
I had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Posted on Oct 05, 2007
Tac and speedometer not working. What's problem?
Jeep XJ it is.
the Cluster is a computer. brain,
a stand alone display.
fuse 16 in PDC (cluster memory fuse)
and fuse 9 in JB . runs it. JB is cab fuse box.
so what works in the cluster, all things, but not speed or tacho.
engine runs ok
scan tool show no DTC errors.?
all warning lights in cluster work? at self test key?????
if the PCM can not comm, to the cluster, the cluster
can not show tach or speed, can't , and cant update odometer either
does the odometer roll moving>? i bet not
the cluster is a stand alone unit, with puter brain (processor)
fuel guage work?
if the scan tool shows U codes or C codes and comm errors
that must be addressed first. (cause)
see?
you cant fix cars, with out a $5 scan tool, cant. why not buy one
and use it?
ask how, 1000's of choices here... and more.
Feb 14, 2015 | 2000 Jeep Cherokee
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
Gas gauge does not work on my 2000 blazer ls 4.3l
Maybe could be ground problem. I would also check fuse/ relay for dash cluster.
Aug 23, 2017 | 2000 Chevrolet Blazer
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
How do I reset the lamp timer on my lp600 projector
You can't. You'll just have to make note of it's current reading just like an odometer of a car when you replace a new bulb.
Dec 06, 2010 | InFocus S/A DOOR LAMP, LP600 Projector...
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
Please help
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Sep 16, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
938 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
