Question about Canon Pixma MP500 All-In-One InkJet Printer
Blue ink I have inserted a blue canon number 8 ink cartridge but because it is a 8 PC instead of just 8... printer says it doesn't recognize cartridge... how can I fix this? Cartridge is right size etc.. just is a photo ink
  • 7redroses Aug 14, 2007
    I figured it out by myself...I used the old gold chip that tells the printer which color I am using off the old ink and replaced it on the new ink cartridge... worked fine so I could print!!! :-)
    President:
  • Canon Master
  • 2,022 Answers
Very good..........
Posted on Sep 28, 2007
Canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris Chrisab123@live.com
Feb 28, 2012 | Canon PIXMA MP160 All-In-One InkJet...
After replacement of the grey ink cartridge by an original new one the printer doesn't recognize the new cartridge. The problem is not solved by inserting another new one also after rebooting the...
Clean the contact points of the cartridge holder with eraser or a fine polish paper meant fro cleaning electronic contacts & re-insert the cartridge.
sonsunny
Jul 06, 2011 | Canon MG5150 AllInOne Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    Canon ink is not being recognized by printer
    To rectify cartridge not recognized error with your printer, first of all, you need to snap the cartridge in and out a few times. If
    this doesn't work, you need to remove the printer cartridge from the printer and then clean off the foil contacts.
    You need to be careful while doing this and do not wipe the nozzles from where the ink comes out. Insert the
    cartridge and switch on the printer. Now your problem might be fixed. If this does not work, it is better to inform
    the manufacturer or contact online technical support experts.
    May 05, 2011 | Canon Office Equipment & Supplies
    When I install non brand printer ink in my Canon MP 460 printer the printer doesn t recognize the full cartridge I just installed
    Canon printers and cartridges have their own chip that recognized the presence of original ink, either the ink you bought is not compatible or the printer need to be reset
    Jul 19, 2009 | Office Equipment & Supplies
    Printer won't recognize the new ink cartridge
    Each cartridge has a electronic chip pre-porogrammed at the factory.
    If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
    Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
    Installed #8 M(magenta ink cartridge) New ink tank.
    The problem can be one of the following:
    1. You have a faulty cartridge chip (return to purchaser and request a replacement)
    2. The chip is soiled (ink or similar is causing the connection to fail) so try cleaning the chip
    3. The chip is not properly mounted on the cartridge (maybe skewed slightly or similar). If so try straightening out carefully and then re-inserting.
    Canon have been known to send out cartridges with bad chips so you should contact them if you bought a proper one and they'll sort you out.
    Mar 09, 2009 | Canon PIXMA MP510 All-In-One InkJet...
    Ink cartridge in being rejected
    If it is a genuine canon ink cartridge. You can sent it back to canon and they will replace it free shipping and charge. I had a similar problem. The y will send you troubleshooting steps first.
    Regards
    Mc
    Jan 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Cannot recognize ink cartridge
    I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
    Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
    Ink Cartridge Error PIXMA MP830.
    pleaz clean the cartridge sensor and also align cartridges by program in your manual
    Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Canon Pixma MP500 All-In-One InkJet Printer Logo
    124 people viewed this question
    old marine
    old marine
