Question about OKI B4250 Led Printer
Waiting your help
OKI B4250 Led printer is not print more than one page. I have tried to resolve the problem by out the blank cartrage but no change.
  • taf4moa Jan 18, 2009
    my installation CD is not working.I cant open it.
  • Anonymous Mar 15, 2014
    B4250 LED printer prints image both vertically and horizontally striped. Vertical stripe pattern is always the same at printing a black page. Due to this the overall contrast is low. Toner is full.
You probably need a new drum (not included with the toner cartridge). When the drum assembly is used up the machine will print one page and then stop. If you open the cover and close you will get a second page. The only way to truely know if the drum is used up is to connect to the printer via a parallel connection and then run a program that is on the driver CD. Then you will get a readout of the drum life. Details are on the Oki web page. This was exactly the problem we encountered with our B4250. I believe you will also have a flashing indicator light on the top panel that doesn't seem to make sense. It will clear along with the problem when you change the drum. Good Luck!
Posted on Oct 03, 2007
  • 161 Answers
Your printer does not have a display to let you know what's wrong with it. To check the unit, you must install the Printer Monitor software that came with the unit. Your problem most probably refers to empty toner or drum replacement.
Posted on Sep 26, 2007
Change sys config emulation oki b4250
You don't need the Status Monitor to do this. Just change the loaded Driver under Properties.
Feb 04, 2010 | OKI B4250 Led Printer
After changing toner it still has a grey spot in the middle of the page that does not print dark enough
The LED array probably needs cleaning. This is located on the lid that you open when changing the drum/toner and is a dark coloured bar going left-right across the lid. Clean this with a cloth. Also check the opening in the drum where you can see the green cylinder from the top for any small obstructions and remove if necessary. Any obstructions or dirt on the LED will line up with the print defect on the page and should be easy to remove. Be careful not to damage the green cylinder.
Dec 28, 2009 | OKI B4250 Led Printer
Oki B4250 PaperJam
clean and wash paper transfer roller or feed roller guide it fail timing
Sep 10, 2009 | OKI B4250 Led Printer
Takes forever to print and when it does wastes several pages
This is a internal malfunctioning. Connection is not properly given. Call support.
Aug 13, 2009 | OKI B4250 Led Printer
PRINTER IS ON. BUT NOT COMING PRINT.SOME TIMES COMES, BUT 1OR 2 PAGE PRINT ONLY
Chek whether your printer is all right. Chek that your contact force is there. I think your printer needs servicing.
Aug 09, 2009 | OKI B4250 Led Printer
Yellow light all the way to the right just flashes?
delete everything printer related. ie. printer, status monitor, and try to print a test page via the button, I think you have to hold it down for ten seconds. I could be wrong though.
Jun 09, 2008 | OKI B4250 Led Printer
Paper jam
try by reinstalling the drivers, if the printer gives the same error then your printer need to be serviced
May 30, 2008 | OKI B4250 Led Printer
Paper jam
hi
open your back side of printer and check fuser aseembly that no any paper jam
Mar 27, 2008 | OKI B4250 Led Printer
OKI PRINTER B4250
You have accidentally pulled the back paper tray. Even when pulled a little, this tray tells the printer to deliver output to the back. This is useful when printing on heavy, or thick paper. Just push it back all the way down to it's original place.
Sep 03, 2007 | OKI B4250 Led Printer
OKI B4250 Led Printer Logo
431 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
