Dryer drum lost screws from inside the drum. replaced them and they came out again. removed back of unit and found that the heating element was broken in places. reconnected and put back onto terminal posts. maybe i did not connect them correctly? when we plugged it in the sparks flew. are all motors compromised or can we replace heating element and cord and be ok
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
SOURCE: MAYTAG Heat Element Shield?
not really put the plate back on it helps force the air across and keeps lint out
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
SOURCE: Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
SOURCE: AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
