ASUS EN8500GT Silent DDR2, Graphic Card Logo
Posted on Mar 18, 2009
Getting constant beep when i add new pci-e card
Hi, im trying to add a new nvidia geforce 8800 pci-e graphics card to my pc, which has a AMD phenom triple core cpu with onboard nvidia graphics. i start by uninstalling the onboard graphics and removing the software. i then install the new card, but when i power up it instantly starts a constant beeping sound.would be gratfull for any potentiol solutions. manny thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
3395
Points
42
Did you plug in the power connector? If so make sure that your power supply is rated correctly.
One continuous beep and not display in the xfx geforce 8800 gtx
.NETFramework and latest updates.. then latest NVIDIA drivers..
if not, then maybe not enough power thru to video card
tip
A list of the compatible PCI-Express 16X Graphics cards for a PCI-Express...
Having trouble finding out which graphics card will work with your PCI-Express motherboard? Here is a list all PCI-Express graphics cards for AMD/ATI Radeon. This list is in descending order. (The top graphics cards from each manufacturer are more recent, have greater memory and are faster while the bottom are older, have less momory and are slower).
If your Motherboard supports PCI-Express X16 then here is a list of compatible ATI/AMD Radeon Cards.
AMD Radeon 6000 Series - (AMD Radeon HD 6870 and AMD Radeon HD 6850)
ATI Radeon 5000 Series - (ATI Radeon HD 5970, ATI Radeon HD 5870 Eyfinity 6, ATI Radeon HD 5870, ATI Radeon HD 5850, ATI Radeon HD 5830, ATI Radeon HD 5770, ATI Radeon HD 5750, ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5870, ATI Radeon HD 5550 and ATI Radeon HD 5450)
ATI Radeon 4000 Series - (ATI Radeon HD 4870 X2, ATI Radeon HD 4890, ATI Radeon HD 4870, ATI Radeon HD 4850, ATI Radeon HD 4830, ATI Radeon HD 4770, ATI Radeon HD 4600, ATI Radeon HD 4550, ATI Radeon HD 4300 and ATI Radeon HD 4200)
ATI Radeon 3000 Series - (ATI Radeon HD 3800, ATI Radeon HD 3600, ATI Radeon HD 3400)
ATI Radeon 2000 Series - (ATI Radeon HD 2900, ATI Radeon HD 2600, ATI Radeon HD 2400)
ATI Radeon X Series - (ATI Radeon X1950, ATI Radeon X1900 and ATI Radeon X1800)
If your Motherboard supports PCI-Express X16 then here is a list of compatible Nvidia Cards.
GeForce 500 Series - (GeForce GTX 580)
GeForce 400 Series - (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420)
GeForce 200 Series - (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 220, GeForce GT 210)
GeForce 9 Series - (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO, GeForce 9400 GT)
GeForce 8 Series - (GeForce 8800, UltraGeForce 8800 GTX, GeForce 8800 GTS (640 MB, 512MB and 320 MB versions), GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8500 GT, GeForce 8400 GS)
GeForce 7 Series - (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600)
GeForce 6 Series - (GeForce 6800 Ultra, GeForce 6800 GT, GeForce 6800 GS, GeForce 6800, GeForce 6800 XT)
For a list of compatible AGP8X Cards for an AGP8X Motherboard click on this link to take you to my other tips page. http://www.fixya.com/support/r6784133-list_compatible_graphics_cards_agp8x
on Feb 10, 2011 • Computers & Internet
1helpful
4answers
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
7helpful
I have vertical red lines generated by my Nvidia 8800 GTS graphics card
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
[email protected]
1helpful
Nvidia geforce 8800 gts code 43 due to vista home premium
Well if you installed the correct drivers for your video card and have the proper power supply requirements, then the vertical lines you're getting most likely indicate that your video card is bad.
Try it in another computer if available, or get another video card.
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Trying to load call of duty 5 world at war . with g force 8800
It will say on the box it was packaged in what the minimum requirements are for the game....
Here is from a site i found....
Processor: AMD 64 3200+/Intel Pentium 4 3.0GHz or better
Memory: 8 GB free hard-drive space, 512MB RAM (XP)/1GB RAM (Vista)
Graphics: Shader 3.0 or better, 256MB Nvidia GeForce 6600GT/ATI Radeon 1600XT or better
http://www.nvidia.com/page/geforce_8800.html
link for your line of graphics cards.
You have not given the entire model # so it is unclear if your card is sufficient, however it does say GeForce 6600GT or better - which yours is
1helpful
GeForce 8800 GT graphics card no display
what motherboard do you have it maybe your motherboard is only up to PCI-E 8 and the card is PCI-E 16 if it is it will not work
1helpful
Having problem with new games
What is the Name and model number of your motherboard
The nforce 430 is an older chipset model and may not use the full capacity of the Phenom processor ...some boards won't even boot and there are Bios updates available for others ...etc
The onboard graphics (geforce 6150 se) is negated by the 8800 GTX ...good card......the problem isn't your video card
Your also running PC5300 ,,667mhz ram ....if board is capable of PC6400 ...800mhz ....there could be another speedup
The bottlenck seems to be with the board and possibly Ram
(Again MB model and name)
Also make sure you have all the latest drivers for Vcards ...chipsets BIOS etc......
XFX nvidia geforce 600gt Pci-e Boot Up Problems
many time overclocking the core does this. Same happens when card is overheating. Check both.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
