Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Nosiy dishwasher The frigidaire dishwasher is very noisy on the drain cycle. It sounds like a hadr vibration. I have removed the bottom tray to look at the pump and cleaned out the impeller area but it looked clean. Stumped in Alberta. Can you suggest a solution? Guy Fiset
  • 75 Answers
Refer to the followin solution for a GE dishwasher.  This simple fix may solve your problem too!
http://www.fixya.com/support/t204050-ge_adorda_dishwasher
Posted on Oct 26, 2007
SOURCE:
Frigidaire Dishwasher has error code i30 and drain pump still runs even with door open. Tried power cycle and comes right back on running and error code i30.
Error Problem / Condition = Clogged filters or a restricted drain line has been detected. ... If the drain line is attached to a disposer, check that the knockout plug has been removed. Frigidaire Dishwasher Error Code = i30. Error Problem / Condition = A leak or over flow of water has been detected in the bottom pan.Feb 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-how-t...
Text info here
Frigidaire Dishwasher has error code i30 Google Search
Jun 09, 2018 | Frigidaire Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Water in bottom of dishwasher after it has run it cycle
    check your drain - perhaps the filter in the bottom of the dishwasher is plugged (look inside the door, remove bottom rack and inspect with a flash light.
    otherwise check your trap or where ever you have your drain hose hooked to drain...
    Best regards
    Ck
    Aug 18, 2011 | Frigidaire Dishwashers
    My dishwasher is not draining off the water properly. It has flooded the kitchen once already. I can here the pump running, but it is a bit noisy. The bottom of the dishwasher is still full of water after...
    Hello & Welcome to FixYa
    Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
    Kevin
    Jan 16, 2011 | Frigidaire Professional Series 24 in....
    Noisy after two yrs
    1. check the rubber belt "wornout" located under you machine
    2. check the motor rubber support insulator may it comes to melted,
    thats why vibration getting up to the body of your machine..
    May 25, 2010 | Kenmore 16342 / 16344 / 16349 Built-in...
    Noisy drain pump on FDB635RF?
    Two questions: 1) Are there filters that need to be cleaned on a routine basis with the FDB635RF? and 2) What causes the scum left behind on glasses and utensils? I use a rinse aid, but doesn't seem to be helping. This is a recent problem.
    Apr 22, 2010 | Frigidaire 24 in. FDB635RF Built-in...
    Water remains in dish washer
    there is a plastic screen in the bottom of the dishwasher towards the back under the tray you will need a 1/4 inch nut driver to remove it, in there are some cutting blades and a pull out cup that is a filter,, pull it out and clean it run the cycles and see if it doesn't drain,, if not your punp could be going bad,
    Jun 06, 2009 | Frigidaire 24 in. GSB5712B Gallery Supreme...
    Loud vibrating/humming noise
    Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
    I hope this helps you. If you need further assistance, please post back and let me know.
    PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
    Apr 21, 2008 | Dishwashers
    Dishwasher is a little noisy when starting up and is leaving rinse water in bottom after unit is done. thank you
    check the drain pump for a blockage,or the pump could be faulty.hope this helps.
    Mar 14, 2008 | Dishwashers
    Dishasher does not drain
    If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
    Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
    KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
    143 people viewed this question
    Top KitchenAid Dishwashers Experts
    Mike
    Smitty
    Level 1 Expert
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
