Question about Hitachi 50UX57B 50" Rear Projection Television
Hitatchi Ultravision rear projection **NO POWER ***
I was watching the new entourage and poof no tv. Now the interesting thing is for about 4 days before that I noticed that I was not getting any sound through my tv as well. And now the tv will not come on at all.. Please any suggestions..
  • 1 more comment
  • smoothair Aug 23, 2007
    hey mike thanks for responding do you have any guess what that would take to fix as far as monies
    So you are saying with parts and all is should be around 150.00 or just with the call..??
    Thank you for your inforamation if you have any other insight on taking care of this issue that would be awesome.. !! You would not have any experience with a Zenith PRO851x would you..?
  • 398 Answers
Usually, when there is no sound, it is because something is not set right in the menu. The fact that the set has shut off completely is quite common in that set. There is a little blue capacitor next to the horizontal output transistor that burns up and blows the small main B+ fuse. Those parts should be replaced by a qualified tech experienced in the Hitachi projection sets who will also check the settings in the menu to get the sound back.
Posted on Aug 23, 2007
  • 1 more comment
  • Mike Longo
    Mike Longo Aug 23, 2007
    When I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
  • Mike Longo
    I charge $150 for the complete repair, which includes parts and labor. I usually have the set done within an hour. I do not have an extra charge for going to the house. Watch out, though, because other shops will have separate charges for the repair and housecall. Steer clear of those shops if you can, because they can end up charging you $400 or more for an hour's worth of work.
  • Mike Longo
    No, sorry, I have never seen or even heard of a Zenith PRO851X.
SOURCE:
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Ours is 2 yrs old.TV turns off by itself every 2-3 min.
U replaced the projection lamp the last 2 years?U used the tv on and watches 4 or 5 hours a day?Yes,the tv projection lamp life is over.Require changing a new projection lamp.
Aug 03, 2010 | Hitachi UltraVision 60VF820 TV
Tv lamp light stays on.
The projection lamp inside on this tv,about 1 1/2 or 2 years,tv on and watches about 4 or 5 hours a day?The projection lamp life are over.Tv require a new projection lamp.
Jul 05, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 1999 hitachi ultravision 60" projection tv and the power will turn on but minutes later it shuts itself off. How do I correct this problem?
When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Apr 03, 2010 | Hitachi UltraVision 60VF820 TV
Hitatchi ultravision 70 in rear projection
Its too simple to do in Java.
Accept String from user through appletviewer.
Use Concept of String .
From Begining fetch on by one character of that String.
now apply Sleep(700) by implementing Thread class.
Inside sleep(700) block simply display each character.
SATYA PRAKASH (INDIA)
[email protected]
09304850882
Feb 12, 2009 | Hitachi 50UX58B 50" Rear Projection...
Hitachi Ultravision 60" rear projection
Time for a new TV. I have searched for manuals and parts. What is available is expensive and may not fix the problem.
Apr 27, 2017 | Hitachi 60SBX72B 60" Rear Projection...
50 INCH HITACHI ULTRAVISION HAS COLOR DIFFERENCE ON EDGE OF SCREEN
Hey, I found this on a blogsite about lcd rear projections....looks like our tv's screens have been burned by the "pillers" that surround the tv when switching from 4:3 to 16:9 or fullscreen... read below, I hope it helps !
cheers!
Vern
Rear projection crt's,the first generation widescreen tv's were notorious for that.Lcd and plasma can have the same problem,but it takes much longer and is not as harsh.Dlp's use tiny mirrors,so it isn't a problem with them.Lcd and plasma tv's should be ok unless you watch them with blck bars on them all the time.
We have lcd monitors at work,and i've seen them after a year with bad burn in.They also run 24 hrs a day 7 days a week with the same display.
GKar posted 2006 Oct 10 15:31 TooLFooL : i have 51" sony rear-projection and those freakin' grey bars burned themselves right into the screen...
I read that to avoid the burning you had to limit your 4:3 viewing time to 15% of total time viewed. (applied to my TV but apparently yours and others as well...great! now they tell you :-x , this applies unless 4:3 aspect was changed to stretched or zoomed...yuck :-x )
This really sucks as a Star Trek/Lexx/Farscape fan as they are mostly 4:3, fortunately the upconvert player/hdmi combo sends a 1080i 16:9 signal to my TV so the effects are drastically reduced by nearly filling the TV without the grey bars or burn in problem without stretch or zoom modes being used. yay! :wink: (default grey bars set to black automatically, apparently grey isn't needed due to screen area covered is sufficient for burn in not to be a problem.)
Apr 11, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi ultravision 53" rear projection lcd tv
You have a problem with the optical engine- The only repair would be to change the engine for about $500-$1,000 plus labor. This is a major repair (sometimes caused by dust particles getting on the LCD panels inside the engine, but disassembling the engine to try and clean it is not a reasonable option)
Aug 21, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
171 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
