Question about Sony Cyber-shot DSC-W50 Digital Camera
Problem in battery
My camera working well for the paset 3 months. But today when power on my camera, a display shows "For use with compatible battery only" and automatically turns OFF.
    Genius:
  • 2,985 Answers
Well is it the correct battery? Assuming it is and should be if supplied with camera- How old is it? Batteries do lose their capacity to hold full voltage as they age - so perchance it is not delivering enough. This is especially applicable to re-chargable batteries. A New battery then
Posted on Aug 14, 2007
SOURCE:
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
I have a Panasonic Lumix DMC-FS11. It has been working perfectly for 4 months now but today when I connect to my computer is does not display the usual message asking where I have just connected to a PC or...
Camera to PC connections for downloading pics are so troublesome that pros never do it that way....they always use a card reader....you should too. Once you do, you'll never go back. typrice_221.jpg
Jul 27, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
Compatible Battery error message
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Sep 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Not showing pictures that i took
may be the bats are not compatible to that cam... check the voltage specification of the battery from the manual and then insert the battery suitable to it..................
just try inserting ur old bats once if the same problem persists then may be the display is out just try changing display..............
the best thing i suggest is you take it to technician ....
Feb 10, 2008 | Samsung Digimax 420 Digital Camera
Powershot s31s
after 3 months the camera powers off while zooming out.
Has anyone a support servive # for Canon?
Dec 24, 2007 | Canon PowerShot S3 IS Digital Camera
Left select key on a cell phone is not working
did u try to get the phone software reflash....that sounds like a software problem not a hardware issue
Dec 19, 2007 | Nokia 6230
Problem
well, i just chcked my camera, and you have the right type....it could be the battery is just bad, though i don't know how to check this without trying it in another camera.
Oct 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Battery problem (DSC W70)
The battery has a third terminal which feeds back data to the cameras microprocessor, if the camera gets dropped the battery block can get damaged and this signal does not get to the CPU. The camera thinks that you're attempting to use a generic battery and displays a warning, then shuts off. Check to see if the 3.0 volt DC voltage is present on the center pin of the battery connector, if it's there, you can safely assume the data is there as well. I wish you luck! Joe Weibel customelectronics.org
Feb 20, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
