Question about Nintendo DS Console
Nintendo ds line on the bottom of top screen
    Guru:
  • 120 Answers
Your screen is damaged unfortunately. It is going to need to be replaced.
Posted on Aug 14, 2007
SOURCE:
Black lines on Nintendo DS lite's bottom screen.
This may mean the bottom screen has cracked, if this happens all the time, its probably damaged.
Apr 14, 2013 | Nintendo DS Console
Nintendo ds lite top screen has lines
sounds like possibly the ribbon, should get it checked incase it dies for good.
Apr 06, 2009 | Nintendo DS Lite Console
Sea Map & Crest
when you get to this part open the southwest sea map on your bottom screen (so you have the gray sea map on the top and your sea map on the bottom screen) now close your DS and than open it again now the crest will be transfered onto your map. go see Lineback after that.
Feb 03, 2009 | Nintendo The Legend of Zelda: Phantom...
My daughters nintendo ds lite bottom screen will not stop shaking
you recalabrate the screen five times , then tap it gentally on your hand
Jan 22, 2009 | Nintendo DS Lite - Onyx
Top Screen on DS only shows lines
I take it the item is a ds Phat??
Problem is the same if its a Lite just a different part.
DS Phat - you need the screen cable that runs between the bottom board and the top connsctor board.
DS Lite, the screen and cable are all in one, so you need a new top screen
Nov 22, 2008 | Nintendo DS Console
Single verticle black line on top screen of ds lite:(
Sounds like you have something wrong with the LCD screen, and there isn't much you can do about it except buy another top/bottom piece from NINTENDO.
Nov 10, 2008 | Nintendo DS Lite Console
Replacing bottom screen on a nintendo DS
The bottom screen is not difficult but it does take some care. As noted in another post, the bottom screen is 3 pieces. The actual screen, the touch screen on top, and then a clear plastic cover.
There is a ton of videos and manuals out here that can get you started.
Two things though!! Wear examination gloves when working with the touchscreen. Any fingerprints on the screen and it will not function correctly. I have had a limited amount of success cleaning the screen after my pudgy fingers hit it.
Also, It can be difficult to get all of the screens lined up correctly. Make darn sure you look at the spacing all the way around BEFORE you pull the stack apart. If you do not get it all lined up correctly the case will not fit! (Even then it may take of couple of tries to get it right)
Good luck with it.
May 22, 2008 | Nintendo DS Console
DS LITE BOTTOM SCREEN IS WHITE WITH BLUE&GRAY LINES
u need a new screen in the bottom, try to get a nintendo brand screen instead of an aftermarket.
Dec 15, 2007 | Nintendo DS Lite Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Nintendo touch screen
Have you dropped the DS? It could be that the ribbon cable on the bottom LCD has come adrift.
Does the top screen display the Nintendo logo when switched on?
Oct 24, 2007 | Nintendo DS Console
Nintendo DS Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
