Question about Frigidaire fes365e Electric Kitchen Range
Frigidaire electric range left front burner
Hi, my left front burner doesn't seem to want to shut off what do i do and how could i solve this problem. thanks
  • 640 Answers
Make sure the knob isnt just worn and spinning on the gas valve shaft.if thats not the case the vavle internal parts are most likley worn,you can rebuild them or just replace the valve itself.
Posted on Aug 14, 2007
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range F7 10
The "F7 10" fault code implies the left front potentiometer/left front burner switch is open and will need to be replaced. Here is that part to order.
Mar 31, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
LG LRE30453 (Electric) Range Problem is front left burner is shut off but the burner remains hot ... Range won't stop beeping. ...
I have a lg electric dual convection range (Model # lre30757st) and the front left burner turns on and off on its own. (It will not remain off.)
Jul 15, 2010 | LG LRE30453ST (Electric) Stainless Steel...
Frigidaire Gallery Range (New). When plugged in, get a PF20 (power failure). Clock works fine. Both ovens work fine. Stovetop does not work. No heat in burners. No display over burner.
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here have mentioned, we saw the puff of smoke and the oven nor the front left burner works. The repairman has to replace a EOC on the back of the control panel and another one in the back on the bottom. The total cost for parts alone is $438 then add in the service call cost. THIS IS THE SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5 years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
Jul 12, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Left front burner
It has a bad element that needs to be replaced
Jun 09, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire fes365e Electric Kitchen Range Logo
83 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
