Question about Sony KDS55A2000 55" HDTV
Tv will not turn on
The tv will act like it is trying to turn on, then it goes off and then four blinking red lights on the power light appear.
  • yerryd Nov 28, 2007
    How did the Technician determine that the fan has failed? Is there some written source that spells out that the blinking red LED Power light blinking 4 times points to fan failure?
    The reason I ask is because my SONY KDS55A2000 is doing exactly as indicated in this problem. However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
    Power light.
    I believe they are wrong, but have ordered a replacement lamp just in case.
  • 105 Answers
4 blinks is a fan error. most of the time its th main fan on the back. blow the inde of the fan out with dust. if this dont work you will need to replace the fan
Posted on Oct 13, 2007
SOURCE:
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Turn power on, green light comes on, goes off, red light blinks once, pause, then four blinks.
Take the tv aparts,the tv power supply board that the board where the power a/c cord is plug it into it.Check the tv power supply board carefully for dying capacitors like bulging up or puffing up onto it tops.Have all the tools.Now basic electronic also can do basic soldering work too?Yes check and replace all dying capacitors.Or tries like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
Hello, I have a 42"
Sounds like a backlight is out. If its still under warranty, exchange it. First try unplugging it for two minutes to reset the t.v.
May 15, 2011 | LG 42LG30 42 in. LCD HDTV
My 42" Phillips Tv will no longer turn on. The power light continues to blink in red and when unplugged and plugged back in it almost acts as though it will turn on again but goes back into turn off mode...
you have a bad power supply, and the tv goes to protect mode, undo the back and look for any bulged or open cap, and replace it.
Fosg2000, please rate me
Mar 17, 2010 | HP LC3760N 37 in. LCD HDTV
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Sony KDS55A2000 55" HDTV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
