Question about LG WM2688HWM TROMM SteamWasher
Fabric Softner section won't fully drain....
Hello please help if you can! The little cup section, where you pour the fabric softner into, won't fully drain. The fabric softner leaves, but water, or a fabric softner/water combo always remains. Any idea what I can do?
  • 4 more comments
  • Jenbar Aug 14, 2007
    Thank you!
    Does the soap drawer come all the way out? Because I tried to attempt this yesterday, and it appeared that it only came out so far. I didn't want to risk breaking anything, so I didn't really try and force it... is it a simple pull out?
  • Jenbar Aug 17, 2007
    Thanks, got it out and cleaned up. I have heard also that I may need to dilute the fabric softner, as it may be too thick. Makes sense, because I hadn't had this problem before - but am currently using different "ultra concentrated" fabric softner compared to what I normally use.
    Haven't used the washer since I cleaned out the drawer - so hopefully it will work.
    Thanks!
  • KMKM May 26, 2013
    MY BLEACH JUST RUNS RIGHT THROUGH THE BLEACH container! Any suggestions? It drains all way into the drawer BENEATH the WASHER, where the clothes are ;--(
  • Anonymous Mar 14, 2014
    fabric softner will not run through
  • Anonymous Mar 18, 2014
    fabric softner is clogged
  • Anonymous Mar 23, 2014
    The fabric softner dispenser will not empty out. Is there a way to clean it out? I've tried hot water and it didn't work.
  • LG Master
  • 744 Answers
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
    Novelist:
    Champion:
  • 244 Answers
Take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
Posted on Aug 14, 2007
  • peter gittos
    peter gittos Aug 14, 2007
    yes it should do it might have like a cente clip to push or when youve pulled it out have a look at the back there will be either a clip or a flap if non of these than it might be like a whirlpool model that u just pull it will be hard because what they have is a small lip underneath which you have to get over the front facia m8
  • peter gittos
    peter gittos Aug 17, 2007
    your ok but u shouldnt have to dilute it u just need to clean once every few months all washers do it common thing m8
SOURCE:
To use liquid detergent does the machine have to come with cup
ROFLMHO Thuli the lid /cap of the detergent bottle is your measure.and yes you just pour it into the water as you would use powder .bleach and fabric softeners are the only thing to keep seperate
May 26, 2015 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Fabric softner "cup" empties right after I put liquid softner in it.
your cup is most likely stuck in the open position due to buildup of fabric softener. Pour two cups of very hot [200 degrees farenheit] water into it and repeat until it works as it should. J.
May 30, 2010 | Kenmore Oasis HE 27062 Top Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric softner wont go in the tub from the top dispenser properly
try thinning your fabric softner with a little water,the viscosity of some is higher than others. (this is how thick it is & varys by brand)i think you will find with a little trial & error this will solve the problem.if not,then contact us again & we will try another option.hope this helps & thanx again for using fix-ya .please rate all replys & again thanx.
Nov 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
808 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
