Question about Blitzz Technology (BWA611) Router
Blitzz Wireless Router not working correctly
I have a Blitzz wireless router. The wireless network was supposedly "set-up" while I was out of town and has never worked correctly. Is there a number for technical service I can call? I mean I don't even know what the name of the network is, nor if there's a password (key). HELP! Anyone???
  • Anonymous Nov 06, 2007
    Blitzz Technology Router
  • 12,061 Answers
Here is a site that will help you setup & or troubleshoot ya rig.. http://portforward.com/routers.htm
Posted on Aug 14, 2007
SOURCE:
How can I secure my network with one main computer and two wireless devices? I have a Blitzz Netwave Base II On a dsl modem. Thanks
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 09, 2009 | Blitzz Technology (BWA611) Router
I forgot my lock code
Are you looking for the wireless key.
It is the program of your wireless router.
You will need to access the router set up to find the network key
Click Here for step by step solution
Oct 27, 2009 | Blitzz Technology (BWA611) Router
MY WIRELESS CONNECTION CONNECTS AND SHORTLY AFTER DISCONNECTS WHY?
It could be that you are too far away from the router. It could also be interference by other wireless networks in your area that are using the same channel as yours.
Try doing a wireless scan using netstumbler. It should tell you what wireless networks are around, and what channel they are using. Try and find a channel that is less populated. Typically setting your wireless router to channel 1, but it depends on how populated your other channels are.
Good Luck.
Jun 20, 2009 | Blitzz Technology BWA711 Router...
I need to set my blitzz router to a new setting using only a g mode and put it on channel 9 using a 10 diget web key security can you do that for me. Linda
Using your wired pc, open Internet Explorer and type http://192.168.1.1 and enter. You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.Click on WIRELESS LAN tab. You should see there the Wireless Network Mode. Change it to your desired mode and also the wireless channel you can change it there. Save the changes you made. That's should do it. Hope that helps!
Apr 25, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Limited or no connectivity with my blitzz 802.11b wireless card
my computer did the samething so i took it to a computer repair shop and they reconfiguered the network connections and now it works fine, but bring your router with you so they can reconfigure that too. it cost my 25 bucks and i think that it was worth it. It saved me alot of headache
Nov 20, 2008 | Blitzz Technology (BWP612) 802.11b...
Securing my wireless
on the modem there will be a code that you put in
you will need a wlan driver installed to get the wireless connections to show up
Jan 20, 2018 | Blitzz Technology Wireless 802.11b...
Laptop will not connect to blitz router
Make sure the laptops wireless card has not been turned off. Many laptops have a button where you can turn off the wireless card.
Jul 09, 2008 | Blitzz Technology (BWA611) Router
Pci bwi 715 not working
All you should need to do is to Discover available wireless networks on the machine with the Blitzz card in (it should be able to discover the belkin Wireless router)
you should have a wireless utility program that came with the card that lets you alter the configuration so that you can connect to this different router.
Oct 10, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Unstable connection
This maybe because both peices of hardware are not set at the lower speed of 54mbps as super g is set at 125mbps and can cause problems with streaming. The speed has to be set the same for both, both beind 54mbps. See if this cures it.
Dec 24, 2006 | Blitzz Technology BWI715 Super G 802.11g/b...
Blitzz Technology (BWA611) Router Logo
386 people viewed this question
Top Blitzz Technology Computers & Internet Experts
didi2005
GFXTech
Andrew
Andrew
Level 1 Expert
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
