Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Oc failed when i switch on the pc the msg is showing that oc failed
    President:
  • 2,961 Answers
In this case i assume the 'OC' is refering to the overclocking facility in your bios, so firstly press F2 or Del when your pc is booting up and, unless you have changed any settings to cause the fault, look in the cmos settings for 'Load Default Settings', save settings and exit for a reboot and see if the same message pops up. If so you may need to check the memory is seated correctly and any other peripheral connected to your motherboard, assuming it is a desktop pc. Isf still no change try resetting the bios by way of a terminal called CLRCMOS or CLR CLK or JBAT1, but you will have to refer to yourmotherboard manula or post the board details back here.
Posted on Aug 14, 2007
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
OC fail warning comes.pc does not switch on at 1st time.next time it asks to do setting in setup. my config is hp dx2280mt, 945 mb, core2 d, win 07 os.
Hi, As I understand, you may have dead cmos battery or is not seated properly. I hope this this will you to solve the problem... Have a Happy New Year...
Dec 30, 2010 | Computers & Internet
Hi,i had a problem with my nokia n73,it always showed a msg that "phone memory is full delete some data"....i tried to change the phone to its original settings from...
switch off ur phone
press
calling button{green button}and
perss on off switch{switch on ur phone}
press contiune they four key
if not come on display
formatting
then formetting ur phone
or select ur country or language
set time
date
ur fault
will solved 10000000%
its my gurrenty
note:
{the work will start full bettry}
idrish 911
Oct 28, 2010 | Nokia N73 Cellular Phone
I am having N73.......Two days before msg memory was full...I cleared all msgs...Now i don have even a single msg in the phone.........But even nw if i try to send msg,it sits in the outbox without getting...
your phone might be infected with virus, reformat phone will do, also reformat mmc, but make sure if you have some important file back it up on your pc,
hard reset is effective, switch off phone press hold green key, * and 3, switch on while holding this three keys
Oct 04, 2010 | Nokia N73 Cellular Phone
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Something worng with it. it shows OC on the temperture number ?
Typically the "OC" indicates your compass is out of calibration.
If you check your owners manual it will tell you how to re-calibrate the compass.
Let me know.
Regards,
Apr 25, 2009 | Chevrolet Blazer Cars & Trucks
MEMORY CARD(M2) IGB 4 SE W2OOI SHOWS FAILED MSG WEN PLAYING
it may be faulty but if you format from start then replace it may solve the problem
Apr 19, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Mp150 E2 and service error 5100
wheres the answer? I am having the same problem right now, just bought 2 new ink cartridges and its not that,,,,
Jun 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
MY APPLICATIONS & GAMES NOT RESPONDING
WHE I CLICK ON GAMES AND APPLICATION I WILL SHOW A MSG OPERATION FAILED. PLEASE HELP ME.
Dec 18, 2007 | Sony Ericsson K550i Cellular Phone
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
135 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
