Question about Saeco Vienna De Luxe Espresso Machine
Saeco vienna express deluve
On the front panel the red light is blinking and i cannot clear it or make!!!!!! thanks ed
  • 29 Answers
That red light is there to tell you many things unfortunatly. It could have timed out on the grinding in which case if you push the brew button it will grind again. If not one of the components might not be in tight. Or it could have run out of water in which case you would need to open the water knob to let water run out the wand. If none of these help you will need to Google" Saeco Repair" and send it to an authorize repair center to have a switch replace.
Posted on Aug 14, 2007
Red light showing when i go touse frother steam not consistent
For Saeco Vienna De Luxe Espresso MachineTeam says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ or buy online in India @
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @
Oct 20, 2014 | Saeco Vienna De Luxe Espresso Machine
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco veinna deluxe coffee machine. i took the
If the light is still then means that either the water tank is empty or the bean hopper is empty.
If the light is blinking then the Dump box, brew group, or drip tray not properly positioned or service door not closed.
So you can make a very good visual check one by one if they are in right position.
Good luck.
Apr 02, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna stopped working
I think its the thermostat fuse in the machine that have to be reset or replaced.
If you will send it to a repair center then contact Saeco USA to see if they can help you.
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
Visit the Web:
Hope this will help you.
Aug 04, 2008 | Saeco Vienna De Luxe Espresso Machine
Broken coffee maker
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Trouble with Saeco Vienna Deluxe
Could be the pump gone bad or the flow meter.
Neither is easy to replace. Needs to be brought in for fixing.
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
231 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
