Question about SanDisk Sansa E280 MP3 Player
"Synchronize to continue your subscription"
I've been using the URGE music service to download music onto my mp3 player, and its worked for eight months. Today I got a message telling me to "Synchronize to continue your subscription". I checked the music service, and everything I downloaded can still play on my computer, but even after I synchronized the mp3 player the message would still appear. How can I fix this problem?
  • 2 more comments
  • beatles girl Nov 06, 2007
    I have the same exact problem. I used URGE as well, and once URGE merged with Rhapsody, the song I bought from URGE wouldn't play anymore. I tried re-formatting, and re-syncronizing with no success. I know this is some sort of liscense problem, but when I try to verify the liscence from URGE, I can't because the account no longer exists in URGE...PLEASE HELP ME!!!!
  • KP78 Nov 21, 2007
    I use Walmart and recently downloaded several songs. Some came in and others give me the sychronize message. I did download some MP3 files and some WMA files.
  • babysteaks Sep 15, 2008
    This is sooo annoying becasue I can only listen to about 1/2 of my music list...I purchased these songs through Best Buy's rhapsody trial offer and now I can;t listen to them without "SYNCHRONIZING"
  • Anonymous Feb 09, 2009
    same problem and switching the usb mode doesn't fix it.
I also did more research due to my device didn't have the USB Mode under the setting menu on the device
1 go to this website first and download and install the updater software http://www.sandisk.com/Retail/Default.aspx?CatID=1376
2 follow a long the directions of the software
then try the above solution of KP78
Posted on Dec 01, 2008
I did a search on "synchronize to continue your subscription" and found this solution on another forum. I tried it and it worked.
"Just changing the sansa transfer mode will fix this issue: If the Sansa player shows MSC, change it to MTP: 1. Eject the device and unplug it from the computer.
2. On the device, push the Menu button.
3. Go to Settings > USB.
4. When you see 2 settings, Auto Detect and MSC, select Auto Detect. (Auto Detect causes the Sansa player to use MTP whenever possible.) Decatur."
Posted on Nov 21, 2007
SOURCE:
What does synchronize to continue music subscription mean?
I have an sansa player and it keeps reading synchronize to continue your music subscription, I downloaded all of m music on the mp3 player, from bear share.
Jun 30, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa rhapsody mp3 player
Your Windows Media Player may need to be updated and the player may need to be formatted. Please try these steps: 1) If you do not have it installed yet, please install the latest version of WMP10. 2) Download and install the quick fix from: http://download.microsoft.com/download/7/e/0/7e055e3f-6014-43bc-b6ff-6a90ced1d032/WindowsMedia10-KB902344-x86-INTL.exe 3) Format m250 device using the Sync mode in WMP. 4) To test, transfer songs to the player using the software for your subscription music service.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Synchronize to continue your music subscription
The "synchronize files to continue" is annoying, and you are likely to get it again. If the music files on your player came from Rhapsody, the short-term solution is to re-synch the files through Rhapsody itself. If your subscription to Rhapsody, Overdrive, etc. ever expires, you will also get this message. The only long-term way around this problem is to only load songs that are in mp3 format (Rhapsody has an Mp3-Only subscription, which is different from its regular subscription; Limewire is another choice - but it is prone to have viruses, and some ISPs will cut off your broadband if you use the service). If you wanted to erase all songs and start over from scratch, you could update the firmware on the player - it will have the side effect of erasing everything on the player.
-Tha Mp3 Doctor
Feb 14, 2009 | SanDisk Sansa e250 MP3 Player
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
Nov 26, 2008 | Audio Players & Recorders
renew your subscription, then reload the songs onto there
Jul 22, 2008 | SanDisk Sansa e250 MP3 Player
Won't play music
you must resynchronize to rhapsody and renew your Rhapsody subscription
Jul 09, 2008 | SanDisk Sansa Clip MP3 Player
Maybe you should mention that if you format, it will delete all your songs?
Mar 18, 2008 | SanDisk Sansa e200 MP3 Player
What does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Jan 23, 2008 | SanDisk Sansa c200 MP3 Player
Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
hmm... well someone probably placed a subscription time on the songs you purchased. the only thing i could think to do would be to try and reload them to your mp3 player
Oct 17, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
137 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
