Question about Samsung HT-DS1000 System
DVD turns off with "Protection" message.
I connected all the wires and plugs from the speakers to the sub-woofer, from the dvd player to the sub and from my television thru audio video plugs to the dvd. Now when I turn on the dvd w/o the sub on...no problems, it starts up fine. But when I turn on the sub-woofer and turn on the dvd ...a message, "Protection" comes up on the dvd screen and the whole thing automatically turns off. I try turning it on again and I can't get to the menu screen or anything. A loading screen comes up with a progress bar, but before it can get to complete that "Protection" message comes up again and shuts off everything. Can someone shed some light on this? Much appreciated and thanks in advance!
  • Anonymous Jun 29, 2008
    Similar problem here:
    Symptom:
    1. When powered on, the main unit displays; "WELCOME TO SAMSUNG DIGITAL", "SW -04 dB", "PROTECTION", then automatically shuts down.
    2. There is an electric burning smell coming out from the Subwoofer/Amplifier unit.
    Simple test results:
    When the DIN Audio Connection Cable is not hooked up to the Subwoofer/Amplifier unit, or when the power is turned off on the Subwoofer/Amplifier unit, the main unit itself seems to be working OK, with no sound of course;
    There is no auto shutdown of the main unit
    No "PROTECTION" warning sign on the main unit display
    The DVD playback works fine (video out)
    My diagnostic:
    1. Power amplifier electronics burnt in the Subwoofer/Amplifier unit.
    2. No problems with the main unit, speakers, etc.
  • 32 Answers
It may be becoz you are using too many things from 1 plug socket / power adapter.
Posted on Jun 26, 2008
SOURCE:
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
How can i enable surround speaker and how can i connect speaker
Muhammad, you need to go to the function that provides surround sound, have a dvd that was recorded in 5.1, have all the speakers and the sub-woofer connected.
May 30, 2013 | Yamaha DVR-S150 DVD Player
I puchased a pioneer vsx-820 receiver yesterday , i have a sub- woofer that only connota via speaker wire ends how can get this to work?
I have the same problem, your sub-woofer is passive and you need a powered sub-Wfr, more money is the only FIX!
Dec 16, 2010 | Pioneer AVIC-D3 Car DVD Player
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
[email protected]
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
Guru
I was moving around my large woofer speaker last night and then all of a sudden the unit went into protection mode. I tried all the various solutions posted on here and nothing worked. Then I went back to my speaker connections on the woofer and unplugged them and plugged them in again and it seems to be ok now. Very annoying problem. Can I suggest unplugging all the speaker cables and replugging them back in. Also another solution may have been holding down the power button when powering up the unit. Give all the above a try.
May 22, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Samsung HT-DS1000 System Logo
414 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
