Ricoh Aficio 2022 All-In-One Laser Printer
Problem for Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 jams duplexing only
By Copyguy123 on Mar 18, 2009
Copier will normal copy fine but jams when duplexing. Paper does not re-enter machine from duplexer, it goes under the paper slot. Seems to be warped from heat. I need a part number of that unit above the fuser that handles the paper.
Clarification Request
Posted by bernu on May 06, 2009
try fresh paper
Solution #1
posted on Aug 21, 2009
Not Rated)
williwilliam
Rank: Master
Rating: 92%, 6 votes
Sometimes with this particular machine on one of the z flaps there is a swing gate at the top, i have had a spring come of the swing gate on the duplexer.
Its a fairly easy one to spot, but ill give you the part number for the exit unit anyways =]
>> A267 4454 << Guide Plate - Paper Exit
Was this helpful?
Yes
No
Solution #2
posted on Jul 17, 2009
Not Rated)
Ickoajnc
Rank: Guru  Ricoh Expert
Rating: 91%, 33 votes
you do not need the part number of that part because the part is working properly.You will have to open the machine and remove the inverter for the duplex that is the part you talk about .
After yo will get out of the machine you will see two solenoids on the part has a brakes from sponge for to stop the noise when the solenoids work. well on some machines on the sponges the glue goes in front and stop the solenoid to work free so remove the sponges and the machine will work again.
You will find the sponges because they are small as 2mm when you will move the solenoid with your hand and see where dose it brakes so on that side is the brake
Was this helpful?
Yes
No
Solution #3
posted on Jun 18, 2009
Not Rated)
Matt_Sr
Rank: Master
Rating: 95%, 7 votes
If you open the duplexer and swing the duplex entrance plate out, there should be a thin little plastic piece that sticks out the top of the back side with a spring attached to it. On this model that piece of plastic breaks off and the duplexor entrance plate does not actuate properly, thus causing the problem you're having.
Was this helpful?
Yes
No
Solution #4
Not Rated)
quennie732
Rating: 86%, 59 votes
On the duplex door rear side there is a paper gate on the first door with a tab that gets acuated to gate the paper for the second pass, I bet the end of the gate is broken.
Comments:
Jun 23, 2009
- Try A8964651 this is an exchange pawl the rear side gets broken because when you open the duplex door the black guide slams around-Carl
Was this helpful?
Yes
No
Solution #5
posted on Jun 17, 2009
Not Rated)
jovanie_rsls
Rank: Guide
Rating: 75%, 2 votes
no you have to clean it the sensor, or you have to check the briege unit
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 2022 All-In-One
Questions and Unsolved Problems for Ricoh Aficio 2022 All-In-One
Do you recommend Ricoh Aficio 2022 All-In-One Laser Printer?
Answer
Answer
We have ours on the network, and it is set up to forward all incoming faxes to an email address... (More)
Answer
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in... (More)
Answer
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check... (More)
Answer
Ricoh FT 3013 error code E 21? how can it be fix
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 2022 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
