DISH Network ViP 922 Logo
Anonymous Posted on May 18, 2013
Receiver freezes after startup
After startup screen all of the lights on the receiver turn off and a fan noise goes on, and I cannot turn on the receiver.
Anonymous
Level 3:
Master:
  • Master 879 Answers
  • Posted on May 18, 2013
Anonymous
Master
Level 3:
Master:
Answers
879
Questions
0
Helped
143221
Points
2676
Firmware corruption. A firmware update only is the remedy. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
My Harbor Freeze fan wont turn on without the light being on, and the remote doesn't turn the light or fan on.
That's what happens when you buy a store brand. You probably need a new receiver. BTW it's Harbor Breeze.
Aug 17, 2013 • Dryers
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
1helpful
2answers
My Sony XMGTR2022 goes into protect mode at
I discovered that there is a compatiblilty problem between the Bose receiver and the Sony amplifier. If I disconnect the receiver from the amp then the amp starts up normally. Apparently the receiver sends out a dc offset or a "thump" that the amplifier doesn't like and goes into protection mode. I solved the problem by putting a 1 second delay circuit between the receiver startup and the amplifier startup. A simple RC delay on the remote input to the amplifier solved the problem.
Shuts off after startup
did you ever get this corrected mine started doing this today as well.
2helpful
Remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
1helpful
Receiver frying noise
I have the same unit and discovered there's 2 cooling fans inside.
one is not working at all and the other is turning very slow.
With that said I'd open the cover and see if it's the fans.
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
1helpful
2answers
Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Mar 17, 2008 • Dryers
Screen remains lit and solid light blue when I turn it on, can no longer see the startup or other screens.
Try this......I had the same problem on my Garmin Nuvi and just fixed mine. When the receiver is lifted, there is a little plastic "reset" button on the back of the unit (near the barcode info). Press in on that and hold. The unit should turn off and then you can power it back on.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
