Question about Sony PlayStation 2 (PS2) Console
PLAYSTATION SLIM PS2 DISC NOT SPINNING
May the motor wire disconected from the board.or IC can be damaged
Posted on Jun 03, 2008
Thre is a white eraser like thing where you put the disc in and there is a groove in it and that lets it spin so try cutting out another groove it might not work but it did for me and i am not responsible if it breaks proede at your own risk
Posted on Aug 14, 2007
SOURCE:
My discs arent spinning. its as if the playstation isnt reading the disc. i have the playstation 2 slim.
Make sure that the disk is clean and also that the ps2 is inside wher you put the disk or the disk might not be allowed
Jan 19, 2010 | Sony PlayStation 2 Slimline Console
Slim PS2, disc not spinning
Well if there is nothing with the lens, i am afraid you're ps2's are garbage now. Your best choice is to sell it to some one, or throw it away.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
On switch button turns green and immediatley turns off again. My disc in the beggining stoped spinning eventhough i can here it trying to spin
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
Nov 11, 2009 | Sony PlayStation 2 Slimline Console
When after powering up and I had press enter, it would say CAN NOT READ DISC.
There are THREE reasons that a Slim PS2 will not read discs. I will start from most common and end at the least common (almost rare) problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other video game] consoles. They eventually fail, especially if you use your PS2 as a DVD player. You can find Slim PS2 lasers at the following website. They are pretty simple to replace:
http://store.richspsxparts.com/v12laser.html
2. There are two "lid closed" sensors on the Slim Playstation 2. They let the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn't really happen by itself... usually if someone drops the console, one or both of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someone installed a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting to determine why your PS2's discs aren't spinning, and how to fix it.
http://store.richspsxparts.com/slpsnospdi1a.html
Nov 10, 2009 | Sony PlayStation 2 Slimline Console
Playstation 2 slim will not read discs. disc inserted and door closed still nothing happens. no laser movement, nothing.
There are THREE reasons that a Slim PS2 will not read discs. I willstart from most common and end at the least common (almost rare)problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other videogame] consoles. They eventually fail, especially if you use your PS2as a DVD player. You can find Slim PS2 lasers at the followingwebsite. They are pretty simple to replace:
2. There are two "lid closed" sensors on the Slim Playstation 2. Theylet the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn'treally happen by itself... usually if someone drops the console, one orboth of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someoneinstalled a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting todetermine why your PS2's discs aren't spinning, and how to fix it.
Nov 07, 2009 | Sony PlayStation 2 Slimline Console
PS2 slim- Disc not spinning
definately the laser has died.
Give us a shout if you need any help.
FixMyConsole
May 13, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 silm not working.
My PS2 slim wont spin a disc unless I put pressure on the top of it. As a temporary fix I place a 10 pound ******** on top of it while the PS2 is in the horizontal position.
Feb 02, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
Sony PS2 discs that were previously used with memory card will not read. other games with no memory work fine. Discs are spinning but browser says disc could not be read.
everything you'll need...this is very common on the ps2 is it a slim or the big one...if it is the fat one here try this :)
http://arstechnica.com/articles/paedia/hardware/ps2.ars
Dec 27, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slim not working
make sure the game disc isnt dirty. also check the eye (game disc reader) to see if its dirty. if u cant see it (you probably wont b able to) then take it to a place like target or gamestop(GS). i reccomend GS.
Jan 02, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
170 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
