Need setup instructions for clickstart my first computer
Batteries inserted, attempting to attach the yellow cable and white cable and get the sound coming through speakers, lights of the keyboard and game station on, but nothing on the tv screen
not sure what cable to plug into which socket at the back of the entertainment unit/tv
Re: need setup instructions for clickstart my first...
I had the same problem a few weeks ago, but i found a soultion!! Look at the back or front of the tv where you isert the red yellow and white cords. Put the yellow in the green plug in instead of the yellow, red in the red, and white in the white. I hope it works out for you !! good luck!!
You can fix this. Inside the battery compartment (where the batteries are inserted) in the base unit, there is a switch that toggles between "PAL" and "NTSC". If you are in the U.S., make sure the switch is on NTSC, not PAL. this will most likely fix your issue.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Plug the Netgear WGT624's AC adapter into a wall outlet. Plug
an Ethernet cable into the yellow Ethernet port on the back of the
Netgear router. Attach the other end of the cable to the Ethernet port
on the back of your modem.
Insert the installation CD that was included with the Netgear
WGT624 into your computer's disc drive. Click the language option you
want to use and then click "Setup."
Follow the setup wizard's onscreen instructions and then
click "Finish." The wizard will automatically detect your Internet
settings. Open a web browser and navigate to "http://192.168.1.1."
Type "admin" in the Netgear's "User Name" text box and then
enter "Password" in the text box labeled "Password." Click "OK."
5
Click "Yes" and wait for the latest firmware upgrade to
install. Double-click the upgrade file and follow the onscreen
instructions to install the upgrade.
6
Click the "Wireless Settings" link if you want to password
protect your wireless network. Click the "WEP" radio button and then
type in the password you want to use for your network in the
"Passphrase" text box.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
you have 5 connectors from the chassis' front (with cable colors): -P LED (white) +P LED (green) HDD LED (yellow/white) RESET (white/blue) POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
The console connects to the red, white, and yellow av plugs located usually at the back, sometimes on the side, of your tv. Typically this will be linked with channel 4, but could also be another av selection depending on your tv.
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
I did a google search -leapfrog my first computer and installation instructions and found it online....I have it as an pdf if you want me to send it to [email protected] ....good luck....
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
They are smooth silver posts with the inside showing a color, usually red, white and yellow.
Look for inputs marked Audio and Video IN.
The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
Do NOT connect your system to anything marked OUT.
Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input White = Audio Input Left (or Mono) Red = Audio Input Right
Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
Connecting to a VCR, DVD-R, Cable Box, etc.
In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
