Question about SanDisk Sansa e250 MP3 Player
Sansa won't hold a charge
When I plug it into the computer it will say it is charging for a chort time (the indicator light moves back and forth on the battery icon) then it stops...when it stops the charging stops..
  • smileymay24 Aug 18, 2007
    It turns out that my sansa has a one year warrenty. I contacted sansa tech support and the friendly tech and I exchanged a series of emails trying to reslove the issue...Turns out my product was defevtive, so they sent me a printable prepaid postage label and the product is going to be replaced with no cost to me!!!
  • 80 Answers
Change the battery you can buy it at sandisk.com.
Posted on Aug 16, 2007
Why wont my eeepc charge ???
There could be three very good reasons I can think of immediately.
1) Check your power adapter to be sure it is working properly. You may want to find someone with a voltage meter to do this.
2) Check the power adapter plug on the laptop. These plugs are bad about becoming loose over time. When we use our laptops we tend to move them around especially if we are holding them in our laps. This causes the adapter plug to be pulled back and forth which can actually break it from the motherboard inside the laptop. No connection...no charge.
3) Be sure your battery is still good. Batteries can go bad like anything else and many times are the reason the PC won't charge.
Aug 26, 2011 | ASUS Eee 4G Notebook
My sansa mp3 has frozen nothing moves,it is on , how can i dislock it
Hi,the Sansa is a portable media player made by SanDisk. As with all portable media players, there may come a time when your Sansa freezes up for one reason or another. This can be incredibly frustrating. Fortunately, there are a handful of different methods you can use to unfreeze the player.
Instructions
Wait for the battery in the Sansa to die completely. Once the battery is dead, you can plug the Sansa into your computer and download a firmware update for your particular model (see Resources below). You can also remove the battery from the Sansa if you want to speed up the process.
Plug the Sansa back into your computer. If the computer recognizes the device, the player should begin charging right away. This will unfreeze your Sansa.
Hold the power button down for roughly 10-20 seconds. The Sansa should turn off. Wait a few seconds and then turn the player back on.
Hold down the center button and the menu button at the same time. Do this for up to 30 seconds while watching the display screen.
Hope it helped.
Thanks for using fixya.
Jan 12, 2011 | SanDisk Sansa Clip MP3 Player
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa express won't turn on
Normal 0 Press and hold the Volume Up (+) and Select buttons at the same time for about 20 seconds
Make sure that the player is charged up.
Try to power reset the device by pressing and holding the center and volume up button at the same time, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
You may need to update firmware.
Feb 07, 2010 | SanDisk Sansa MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
Charging sansa mp3
try putting it into recovery mode. you can do this by putting the hold sign to where it shows orange, then holding the record button down while holding the power button down and continue to hold them at the same time. make sure your sansa is plugged into the computer while you put it into recovery mode. for more information here is a link to the forums where they tell you how to put it in recovery mode http://forums.sandisk.com/sansa/board?board.id=e200
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
SanDisk Sansa e250 MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
