Question about Panasonic Toughbook CF-27 Notebook
Does not shut off
Win98 se closing screen "windows is now shutting down" comes on and stays there forever Only manually shutting the power swith shuts it off. paul
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Download the 'Windows 98 Shutdown Patch' and run it. That should fix things.
Posted on Mar 29, 2009
  • Panasonic Master
  • 12,061 Answers
Hi here are so links that may help you troubleshoot your shutdown issues... www.dove.co.nz/support/win98se-fix1.html support.microsoft.com/kb/238096 209.167.114.38/support/techsupport/tsbs/all/-TSB000739.htm This used to be a nightmare problem.. waaayyyy back..
Posted on Aug 14, 2007
6ya staff
SOURCE:
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
Jul 21, 2011 | Computers & Internet
Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
Feb 06, 2010 | Lenovo ThinkPad T400 PC Notebook
WINDOWS NOT SHUTTING DOWN COMPLETELY
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
I installed my free upgrade of Windows 7, and now am having alot of problems with my laptop. When laptop boots up, the Windows screen/logo is all distorted. When I close laptop and open again, it never...
Go to the tech support site of the manufacturer of your laptop, search your model, and find appropriate drivers for your laptop. Some things may not have installed corrected (or at all) when you updated to Windows 7 from Vista.
Dec 10, 2009 | Acer 91.63X07.001 Keyboard
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Dell Inspiron 1520 won't shut down when printer connected.
Try disabling the startup items or edit it. Go to Start -> Run. type msconfig. Choose Diagnostic Startup. Reboot.
Please rate this if this is helpful.
Dec 09, 2008 | Computers & Internet
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Panasonic Toughbook CF-27 Notebook Logo
118 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
