Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore dishwasher model 665 motherboard
I replaced the motherboard, put everything back together, but dishwasher is still not working. When I plugged the dishwasher in, the heating element get hot, but if I push the start button, nothing happens. Help!
    Novelist:
  • 148 Answers
Relay or sensor
Posted on Dec 21, 2007
SOURCE:
What can I do my dishwasher Kenmore model 665-13834K601 the Cancel and Normal wash lights are blinking and won't work
Try this, unplug it from wall outlet for one minuet to reset its processor. Then plug it back in to see if that worked.
Dec 03, 2014 | Kenmore Dishwashers
Kenmore 665 dishwasher problems
Check the door latch and switches.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 22, 2014 | Kenmore Dishwashers
Replacing the control panel on my kenmore 665 dishwasher
double check the part #...match the two together. If everything is the same other then holes see if you can hook up to work...if it does make new holes.
Mar 29, 2014 | Kenmore Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
I have a kenmore elite dishwasher model#665. no power
Nearly all Kenmore dishwashers have a thermal fuse inside the operator console. If the fuse blows, it will exhibit the symptoms you describe. If you post back with a COMPLETE model number (located around the tub opening with the door open), I can verify, provide you with a part number, and explain to steps required to replace it.
NOTE: "665" is the manufacturer code, which identifies the manufacturer of your dishwasher as Whirlpool.
Nov 18, 2009 | Kitchen Ranges
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Kenmore b/in dishwasher model # 665
There is an Interlock switch on the door that stops all funksions of the machine when the door is opened.
WARNING! BEFORE WORKING ON THE MACHINE DISCONECT POWER FROM THE MACHINE.
Generaly you need to remove the Control Panel Top Of Door (sometimes the whol inner linning of door) to access the Micro Switch that performs this very nessasary function,this switch should be the problem and will need replacing.
They are very cheap to buy.
Take it slowly,take photos before starting work and during so that you can not forget how it oes back together.
Dec 14, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Jan 30, 2008 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
622 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
