Question about Toshiba Satellite A105-S4004 Notebook
Toshiba a105 screen goes blank
My Toshiba laptops a105 monitor goes gray with slight white lines on it after a couple of minutes. I hooked it up to my desktop monitor and that monitor goes gray too. The fan is working and I I use one of those fan boards. Any suggestions?
  • Nevin77 Nov 19, 2007
    have the same problem with my A105.
  • Anonymous Mar 29, 2014
    by using scotch tape will that repair the monitor white vertical lines on my toshiba screen
  • 60 Answers
Sounds like GPU failure. unfortunately its nigh on impossible to replace without replacing the whole board which can be expensive. I saw a few on ebay for around £120.
Posted on Aug 14, 2007
SOURCE:
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
Toshiba A105 S2719 screen problem
Is this behavior irrespective of power condition of the laptop, ie both ac and battery?
Please see bios bulletins for your system here. Sometimes a bios update can correct this kind of problem...
However, also note this article.
In the probable event that none of that works, it's probably your inverter or backlight (EL) panel, both of which can be replaced. The white lines are not a good sign. See other thread discussions of same here and here.
Google "diagnose laptop monitor failure" for more, or see this repair guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 19, 2009 | Toshiba Satellite A105-S2719 PC Notebook
My toshiba a105-s4344 has a line threw the screen where the top is darker than the bottom by alil bit and when the screen moves around the screen flashes and goes nuts what do u think the problem is the...
The problem with Lcd screen is that if you see line through them there are three possibiltys 1Your cable connection from the laptop to the screen is loose 2 the inverter is failing which mostlikly you will see backlite flashs and then blank screen or pixcels seem to get lost and return 3 bad screen pixcel lost in hole sections or line or lines than a total lost of screen chech all the connections first .connect a monitor to the laptop and see if you have the same problem if so it may be the video card on the board
Mar 25, 2009 | Toshiba Satellite A105-S4344 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
A105-s2716
The problem with the LCD screen , if the external display is working fine. The LCD needs a replacement. The same thing happened on my Dell and we had to replace the Lcd. The same can occur because the LCD cable gets damaged when you open or close the LCD
Thanks
Proton
Aug 02, 2008 | Toshiba Satellite A105 Notebook
Toshiba A105-S4254
Probably its the inverter.
May 12, 2008 | Toshiba Satellite A105 Notebook
Laptop would power off after 10 minutes....
open it bk up u may have knock any wires or links to the screen ps dont open laptops unless u no what u are doing
Jan 14, 2008 | Toshiba Satellite A105-S2717...
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
237 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
