Question about Visioneer OneTouch 7100 Flatbed Scanner
Visioneer scanner light barely moves HELP!
My Visioneer 7100 powers up and scanner light bar comes on but when i try to scan the light bar only moves about 1/2 inch then returns, giving an error window. i had to use a different adaptor but the voltage is the same. what is going on?
  • luis214377 May 26, 2008
    mine barely moves too it moves like 2 or 3 inches and it says that it might be in use by another program but it isn't and the light that has to be gree to be ready to use is always orange i don't know what to do
  • John Waaser Dec 18, 2008
    I took a Visioneer 7100 that was working at my home, and went to another location with my laptop, and downloaded the driver from the Visioneer site, and immediately had the same problem. I took it home to the computer to which it had previously been installed, and the problem persists. The carriage is unlocked--and that may be the problem. I had it in my car trunk for several weeks without locking the carriage. I can push the carriage all the way to the end, and back again. If I leave it in the middle, and power up the scanner, the motor will send it back to the park position. In all other respects it seems to be fine, but the carriage will only move 1/2" or so, then back. It will do this generally three times, and then issue an error message which suggests that another program may be scanning, but it is not. Once it even suggested that the carriage was locked, but it is not. I am at my wit's end here. My light is also orange at all times. I assume that this is a board problem of some sort????
  • 35 Answers
First u need to install proper drivers for ur . If installed then this may cause due to scanner hardware problem. This can be repaired . Go to ur scanner Provider for reparing. Thank you.
Posted on Aug 14, 2007
SOURCE:
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
OneTouch 7100 Flatbed Scanner: Hello, I have a visioneer 7100USB scanner (from lo...
Try typing the model details into google ( or look on your manufacters website )
Alot of blogs find ways to bypass such things.
May 18, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Cannot find driver for vista operating system, for visioneer 7100 scanner.
According to Visioneer themselves no Vista driver has been produced. "7100 TWAIN Driver Only included on the installation CD
Windows XP / 2000 / Me / 98SE
There is no updated driver available."
Feb 07, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Is there a driver available for the Visioneer 7100 usb?
maybe this will help.http://social.technet.microsoft.com/Forums/en-US/itprovistahardware/thread/f2d460e8-bb39-4576-86f6-4615fdb88049/
Nov 12, 2009 | Visioneer OneTouch 7100 Flatbed Scanner
I need to connect Visioneer onetouch 7100 to windows Vista
There are no Vista drivers for this scanner
http://support.visioneer.com/products/7100/default.asp
Jun 10, 2009 | Visioneer OneTouch 7100 Flatbed Scanner
Help me install my visioneer one touch 7100usb scanner
Here is the VIsioneer download site for your model:
Download and install the driver. The instructions are indicated on this page also.
http://support.visioneer.com/products/7100/downloads.asp
Mar 13, 2009 | Visioneer OneTouch 7100 Flatbed Scanner
Troubleshooting Visioneer One Touch 7100 USB
Okay , You can scan once. Then close the scanner monitor controls. Then START-Programs-Paperport-Scanner Monitor. This reopens scanner Monitor for next scan. You may also have to START-Run- then type in %Temp%. Go to the One Touch folder to get your pics and delete all files before you scan another pic.
Aug 24, 2008 | Visioneer One Touch 7600 USB
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
Only dim light on the left hand corner is on. No Flash. No bright light any longer.
Sounds like the Power Supply has faulted...OR perhaps it is the USB cable try another one if ya can... else sry is Kaput!
Jun 25, 2008 | Visioneer OneTouch 7100 Flatbed Scanner
Visioneer OneTouch 7100 Flatbed Scanner Logo
145 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
