Question about Zenith DVT412 System
Double image and only in black and white
I tried switching to PAL and auto but the problem persists -please help
    Genius:
  • Zenith Master
  • 1,550 Answers
Without disc on the tray push the stop button for 5 seconds
Posted on May 25, 2008
Image blurred with white dots and image not stable
Good day!
Please try to look first the nstc/pal set-up of your player that found on the rear side..
If your settings is pal please try to change it to nstc..
and if your settings is nstc change it to pal..
If the problem persist,just add a comment to proceed the next troubleshooting.
Thank you and good luck
Jun 18, 2011 | Panasonic DMPBD65 BluRay Player
I just purchased a dvd player and it's showing vertical lines.
PLEASE CHECK PAL AND NTSC SELECTION....IF YOUR REGION IS PAL SELECT PAL IN DVD SETTINGS....OR IF YOUR REGION IS NTSC THAN SELECT NTSC IN DVD SETTINGS....ITS NOT A PROBLEM...JUST TRY TO SWITCH PAL AND NTSC IN YOUR DVD SETTINGS....U WILL DEFINATELY GET THE RESULT
Nov 08, 2009 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd player is producing double images
Go into the units system menu and change the unit to NTSC or PAL, depending on what country you live in. Good Luck
Jun 20, 2007 | Zenith DVT412 System
Black and white images
I had the same problem with my Playstion2. I found that the playstion was givin an NTSC video output but the TV was only for PAL. try it on a TV that is PAL if your gamestation is PAL or on an NTSC tv if its NTSC. Does this help?
May 26, 2007 | Microsoft Xbox Console
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Playing burnt dvds in black and white
Cause: You are trying to play a DVD with NTSC-standard on a PAL-videodevice. Solution: switch your video-device to NTSC-standard or to "AUTO". Explanation: I had this "Black&White" problem after I played a DVD which I downloaded from Internet. My video-device (beamer) was set on PAL and gave black&white pictures, but when I switched it to "NTSC" the problem was solved. Apperently the Sony DAV-DZ100 switches automatically from PAL to NTSC when needed.
Nov 01, 2006 | Sony DAV-DZ100 System
Zenith DVT412 System Logo
63 people viewed this question
Top Zenith Audio Players & Recorders Experts
Marvin
Marvin
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
