Question about Epson Stylus CX7800 All-In-One InkJet Printer
Scanner stopped on my Epson Stylus CX7800
When I try to scan or copy something on my CX7800 it prints all black, as if the scanner is not picking up anything. The light is working and moving. The glass is clean. I can print from my PC. I am at my wits end. It worked the last time I used it (few weeks back), but not now. Any ideas?
  • 10 more comments
  • Anonymous Nov 01, 2007
    I selected the problem exactly as was stated
  • Anonymous Dec 07, 2007
    I REINSTALLED SOFT WARE, CLEANED INK NOZZELS CHANGED USB HUB STILL SCANS ALL BLACK
  • Anonymous Dec 20, 2007
    The scanner light works and it moves. When the page prints, only approx. 1/2" on each side appears. The rest of the page looks like static on a television. We have installed it again and tried everything we know. Can you help.
  • ebony333 Dec 31, 2007
    SAME EXACT PROBLEM!!!!
  • tiffanypoe Jan 01, 2008
    my epson scanner does the same it will not scan i cant see anything except alittle on each side when it copies or scans
  • Anonymous Jan 08, 2008
    The scanner light works and it moves. When the page prints, only approx. 1/2" on each side appears. The rest of the page looks like static on a television. We have installed drivers again and tried everything. Thinking of replacing the scanner head but have not located parts yet. Repairs at service centers will cost as much as scanner. What a disappointment. Anyone have an epson cx7800 that has a functional scanner but printer gone? Im interested.
  • jctrueman Jan 24, 2008
    Exact same problem as described by everyone here -- static covers the entire page except for a 1/2" strip of printing. I've cleaned the glass, the printheads, and reinstalled the software. I also wrote Epson's online technical support explaining everything. They have not answered, let alone even acknowledged receipt of my email. Now I see that it appears to be a chronic problem with the 7800. No wonder they didn't answer me! Has anyone replaced the bulb or bulb mechanism?
  • annbea Feb 18, 2008
    I have the same problem with my CX7800. Tried the same fixes as eveyone else with the same (lack of) results.
  • collich Feb 19, 2008
    same problem and Epson won't answer my email either. No more Epson products for me!
  • Anonymous Feb 20, 2008
    I also, had the same problem. my cx7800 started to scan with black and colored lines across 3/4th of the page. I finally solved the problem. Try downloading the new twain driver
    1. TWAIN Driver and epson Scan Utility v2.73A
      Windows XP, Windows 2000, Windows Me, Windows 98SE
    2. Find your epson scanner drivers from the install disk. delete them.
    3. Thenclick on the zip file 11577.exe to unzip the files from epson and install in the epson folder for your scanner.
    4. Then open up your printer properties and click the advance tab, then click on new driver. Welcome to the new driver wizard pops up, follow the prompts to add the driver, make sure to show your printer type and model.
    5. It will them tell you that you are about to add a new driver for epson Stylus CX7800 Series, Intel, Windows 2000 or XP. then click finish.
    6. This is the tideous part. Click on the scan icon on your desktop. Check to see that vers. 2.73 is isntalled. It will show on the start up screen. Start scaning in one of the modes. You may need to run the scan several times in each mode. You will notice that the scan starts to change each time and the lines start to disappear. Make sure that you run the scan several times in each mode (Home, Professional and Full Auto Mode).
  • Kssbonemd Apr 11, 2008
    Exact same problem in both scan mode on a Mac and if I try to copy directly off the flatplate. Epson's unhelpful answer was that there was a hardware problem with the scanner and I could ship it out of state to their closest certified repair facility, for more than the scanner cost, since it was two days past the warranty. Looks like a light problem because film scanning works fine. I can't find a way to replace the light element either and epson certainly isn't helping.
  • Anonymous Apr 03, 2009
    call for service. What do I do? Thanks, Sharon
The real problem is that the light bulb in the flat bed has burned out. After 2 years or more this is normal......
To verify that it is the lower bulb, scan a slide or film, notice that the light bulb turns on in the lid.
This is easy to fix with a little skill with a phillips screw driver after getting the replacement part. Some patience with sticky tape and remembering to put the parts back togther correctly.
REALLY VERY SIMPLE
Posted on Apr 14, 2008
DON'T BUY EPSON..
Posted on Jan 30, 2008
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printer works but scanner does not
if you download the scc it will reset your printer has new this should work
Nov 17, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Scanning trouble PLEASE HELP!!!
1. does scanning from the pc looks good ?
2. printing photos from the pc looks good ?
3. does standalone copy (placing image on the scanner bed then pressing the COPY button on the printer) looks good ?
Dec 31, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Epsom CX7800 Scanner Printer
Windows XP has its own scanning software found within the control panel under scanners and cameras. This appears to provide a more direct method of controlling the scanner because it is part of the OP Sys as opposed to 3rd party scanner software. If the scanner is installed and it appears as an installed option, then try using this approach instead of the actual scanning software.that came with the scanner.
Dec 23, 2007 | Computers & Internet
EpsonStylus CX7800
first disconnect the printer from the computer
then powercycle the unit and observe if it is recognizing the inks
if u get the red ink lights on, try re-seating the inks
if that doesnt work, contact manufacturer regarding the inks
Dec 21, 2007 | Office Equipment & Supplies
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Epson Stylus CX7800 All-In-One InkJet Printer Logo
572 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
