Question about Panasonic TH-50PHD8UK 50 in. Plasma Television
Input/Output Connections Hi all! This model doesn't seem to have component video connection jacks on the back nor does it seem to have regular video input jacks (the place of the jacks are there but no jacks). Is this normal? If so, how can I get this display unit configure so I can get component and video input accessibility?
This model Panasonic is a monitor. Component video, S-Video, and audiio connection ports are on the bottom of the unit. Once the unit is wall mounted you can hardly see them, hidden behind the front leading edge of the case. Two speaker connection terminals are found
slightly above the bottom edge at extreme left and right. The main power button is also on the bottom left.
Posted on Jan 03, 2008
SOURCE:
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Need owners manual for proper connections to tv w/direct connections I hsve a sony dvp ns300 cd/dvd player
The connection you use will depend on the TV. For the best picture, connect component video cables (not included) from the DVD player's output (to the right of the other jacks on the back of the unit) to the component video in of the TV. Then connect the Right and Left audio from output 1 to the appropriate audio input of the TV. (These may vary depending on the TV and other devices connected to the TV. They might be audio 1 or part of a group with the component video inputs.)
Otherwise you can use an S-video cable connection and the separate audio cable or the composite video cable (which has 1 yellow RCA plug for video and 2 others (red and white) for audio). Connect these from the output of the player to the matching input ports of the TV.
For TVs with only RF in, you need a composite video to RF modulator (converter). See a store like Radio Shack for this.
The manual is available from Sony: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPNS300 . Pictures of the connections start at page 15 and more detail is provided from page 17 through 23. See the manual for details if you have a home theater system or other external speaker option.
I hope this helps.
Dec 08, 2010 | Sony DVP-NS300 DVD Player
2004 jvc 56in projection tv, has sound but no picture
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
Component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
Apr 15, 2010 | Marantz SR5001
No picture from monitor out on Onkyo TX-DS898
I realize you may have already doubled checked but make sure you follow this from the manual:
If the satellite tuner / cable box is equipped with an S video output
terminal, connect it to the S VIDEO 3 (or 4) IN terminal with an S
video cable. If it does not have an S video output terminal, connect
its video output terminal to the VIDEO 3 (or 4) IN terminal using an
RCA-type video connection cable. You do not need to connect to
both the S VIDEO 3 (or 4) IN and VIDEO 3 (or 4) IN terminals. If
the satellite tuner or television has component video outputs,
connect them to one of the COMPONENT VIDEO INPUT jacks.
With the initial settings of the TX-DS898, the VIDEO 3 and
VIDEO 4 input sources are set for the COMPONENT VIDEO
INPUT 2 jack.
If the video connection is made at COMPONENT VIDEO INPUT
1, this must be changed at the Setup menu: Input Setup → Video
Setup → Component Video (see page 35).
Using an RCA-type audio connection cable, connect the audio
output terminal on the satellite tuner or television to the same
VIDEO 3 (or 4) IN audio jacks on the TX-DS898. Make sure that
you properly connect the left channel to the L jack and the right
channel to the R jack.
If the device has a digital output jack as well, be sure to also connect
it to either a DIGITAL INPUT (COAXIAL) or DIGITAL INPUT
(OPTICAL) jack on the TX-DS898 depending on the device.
With the initial settings of the TX-DS898, the VIDEO 3 input source
is set for digital input at the OPTICAL 3 jack, and the VIDEO 4
input source is set for digital input at the OPTICAL 4 jack.
If the digital connection is made at a different jack, this must be changed
at the Setup menu: Input Setup → Digital Setup (see page 33).
Apr 15, 2009 | Onkyo TX-DS898 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
VCR upconversion
check the wires, they could be bad. Or maybe your vcr head needs to be cleaned
Dec 26, 2005 | Yamaha HTR-5860 Receiver
Panasonic TH-50PHD8UK 50 in. Plasma Television Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
