Question about Pioneer SD-P62A3-K 62" Rear Projection Television
Pioneer rear projection tv in standby mode
It will power up, but then go immediately in standby mode and will not come on. It just started doing that for no apparent reason. Any help would be most apprecaited. Thanks, David
    Genius:
  • 1,153 Answers
If the relay clicks when pressing power check C258 in video assy.
Posted on Aug 16, 2007
Tv shuts off go on standby wont power back up
make sure it is pluggen in all the way to the source of video or may need new cord
Nov 24, 2009 | Pioneer SD-P55A5K 55" Rear Projection...
Pioneer SD-P55A5 shut off during use and wont advance past standby mode
This is a problem related to the hue controlls in the TV. It is quite common.
Fix: You can go into the TV settings and try adjusting the hue/tint there.
If adjusting settings does not work, request help from a technician to fix it for you since it will take adjusting the hue internally and if you do not do it correctly it can damage your television.
I hope this helps ya!
Jul 28, 2008 | Pioneer SD-P55A5K 55" Rear Projection...
Tv only stays in standby mode
Replace Fuses 302 5amp and 303 5 amp Resolder all poor connection on power supply board and Replace Both STK ICs they are big black ics STK392-180s is best ICs Call Mats 1-800-628-1118 This should have you back to watching TV again.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
I need a service/repair manual for a Pioneer SD-643HD5.
you dont need a service manual. the problem is the convergence chips and it has been plaguing these pioneers for years it is either the bad solder joints on the chip itself or the chip is trash anyway go to tvrepairkits.com and they will help you get everything u need
Mar 26, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
May 07, 2008 | Pioneer SD-P62A3-K 62" Rear Projection...
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
217 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
