Question about Apex Digital AT1314DV 13 in. TV/DVD Combo
Resetting the parental control password?
I don't remember my parental control password. Is there a way to reset this password?
  • Anonymous Mar 27, 2014
    channels are locked from parental control
    Genius:
  • 1,153 Answers
Try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Posted on Aug 15, 2007
Forgotten parental control password
Try returning to the initial setup routine and resetting or disabling the pc password
May 31, 2013 | Viore 1111010006 Main Board for LC13VH54...
Resetting parental controls
there seems that only 4 digits are the max but I could be mistaken, as far as reseting the password there is nothing listed on the Vizio website in the manuals ect for reseting the parental controls, probably due to security for the owner.
But there is a solution
if you call 877 MY V I Z I O
with you model number of your unit and make them aware of the parental lock issue there might be a way for them to explain the resting everything back to factory settings.
Aug 11, 2008 | Televison & Video
Forgot passcode
Kindle Fire:
If you can't remember your lock screen password or PIN, you will need to reset your Kindle Fire.
Important: Resetting your Kindle Fire will remove your personal information (including your lock screen password or PIN), Amazon account information, and downloaded content and apps. Any content you purchased from Amazon is automatically saved to the Cloud. You can download that content when you register your Kindle Fire to your account again.
  1. From the lock screen, slide the Unlock Bar from right to left.
  2. Enter characters into the prompt ten times. You will receive several warning messages. Dismiss the warning messages, and continue entering characters into the prompt.
After you've entered the incorrect password or PIN ten times, your Kindle Fire will reset.
Kindle Paperwhite:
If you can't remember the passcode for your Kindle you'll need to reset your device.
  1. Transfer from a Computer to Your Kindle Paperwhite.
  2. You can't reset your Kindle Paperwhite if Parental Controls are set. If you forget your password, reset your Kindle by entering "111222777" as the Parental Controls password.
    Important: Resetting your Kindle will remove all content downloaded to it. Any content that is already saved to Your Kindle Library in the Cloud will remain in the Cloud. You can download that content again if you register your Kindle to your account again.
    1. From Home, tap the Menu icon, and then tap Settings.
    2. Tap the Menu icon again, and then tap Reset Device. Your device will power off and power back on.
    To use your Kindle again, you'll need to connect wirelessly and register your Kindle.
May 18, 2013 | Amazon Kindle Wireless Reading Device
LTA260 digital converter box. My nephew played with it asnd entered a pass code in the parental control. Doesn't know the number. I'm locked out of most channels. How can I clear the code?
U can't in most cases,that why they called a secret passwords codes.U only can tries this by unplug the converter box and replug it back 24 hours later.Go to parental control codes mode and resetting the mode,might resetting the mode and erase the secret passwords codes,only some models of boxes could do this,ur included don't know sorry.
Aug 06, 2011 | Televison & Video
I forgot the parental control password, how can I do?
At one time Vizio used the code "0000" as a default built in parental control password. If you go to the screen when you setup your parental control password and enter that code you may be able to access the system again and change the password to whatever you want to use.
Unfortunately if the "0000" password does not work you will have to contact Vizio support and have then step you through the process of resetting the password. Due to security issues they will only assist the registered owner with resetting the password. If you go to the website for your TV at the following URL:
http://www.vizio.com/e420vo.html#support
On the Top Menu you will see SUPPORT as one of the items you can choose. The drop down menu gives you a number of choices. You will probably have to use the chat option. They will probably ask you to verify the date of purchase on the TV from your receipt. They should then be able to walk you through the procedure to reset the password.
Jun 27, 2011 | Vizio E420VO 42 in. LCD HDTV
@YAHOO.COMI CANT REMEMBER THE PARENTAL SETTINGS PASSWORD? WHAT DO I DO ?
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
May 09, 2011 | Microsoft Xbox 360 Console
Daughter has set parental lockout code on an xbox and can't remember. how do we reset it?
Here is a good article on resetting it:
http://www.techlore.com/article/10624/Resetting-the-Parental-Lock-Code-for-the-XBOX/
Sep 19, 2009 | Microsoft XBox Controller S ( Brand) X-Box...
Cant remember parental control code.
All Details Below On How To.
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Jun 25, 2008 | Microsoft Xbox Console
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Apex Digital AT1314DV 13 in. TV/DVD Combo Logo
464 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
