Question about HP StorageWorks ESL712e Ultrium (AA934B) LTO 2 Tape Drive
Ultrium LTO 2 Tape Drive
Tape won't eject. We replaced our 'friday' tape with Thursdays to try to retrieve a lost file. Ejected Friday's OK but now can't get the Thursday tape out. Consequently, we haven't backed up since 10th August. Anything a non tech can do? Our IT administrator will be in tomorrow to poke around. (PS we're in Australia, currently 11:57am 14/8/2007
  • marcust42 Nov 28, 2007
    Have a HP ultrium 460 LTO2 with a tape stuck; green light steady, yellow error light flashing and tried solution above. The unit makes a tada tada tut sound repeatedly but does not eject tape. Any other ideas???
    Thanks,
    Mark
  • LTO 2 Tape Jul 17, 2013
    A 1st class product and service from a 1st class trader. From my own experience I cannot recommend them that LTO 2 Tapes 200GB/400GB http://www.digitaldevicesonline.com/lto-...
Try holding the eject button down, for a long time, about 20 seconds (1 and 2 and ). This resets the tape drive, the lights on the front should go off, then come back on again. The tape will either eject automatically or will eject after the button is pressed normally.
The only time this dosen't work is if the tape is still out inside the drive.
Posted on Jul 09, 2009
Hold the eject button in for 30 seconds or so
Posted on Aug 19, 2008
Turn off the tape, turn it back on, press the eject button instantly for two to three times, and you will make it out. regards, [email protected]
Posted on Sep 14, 2007
SOURCE:
Ultrium 2 drive automatically ejects tape
Are you using the correct tape? If you try and use an LTO3 or LTO4 tape then it will just eject.
Does the drive make a clattering sound when first turned on and it goes through its POST ?
If the answer is YES then the drive has had a damaged tape loaded into it and the drive now needs repair.
Goto www.tape-drive-repair.com for repair or replacement options as these are quite inexpensive these days
Also try inspecting your media as per the guide here.
http://tape-drive-repair.com/tools-and-information/lto-media-inspection-guide/
If you find any damaged tapes then make sure to throw them away as should you reload these tapes they will go on to break your LTO drive again.
Sep 20, 2012 | HP StorageWorks Ultrium 460 () LTO 2 Tape...
Hp storageworks ultrium 448 drive light blinks orange
Hi John, not sure from your description which light you refer to.
But this sounds like your drive has either had a read / write issue - in which case you need to run a new cleaning tape through the unit and then retry using a brand new data tape - OR it has had a damaged tape loaded into it which has now broken the tape drive.
If the drive has been broken then try contacting www.tape-drive-repair.com who can repair or replace it for you and also look at
The guide will tell you how to inspect ypoour media for damage and prevent you from reloading a damaged tape which will break your drive again
Sep 12, 2012 | HP StorageWorks Ultrium 448 LTO 2 Tape...
LTO tape Drive keeps ejecting tape
This could be that you are putting an LTO3 or LTO4 tape in the drive (or expired cleaning tape) Or it could be that the tape or tape drive has a problem reading the data.
Try using a brand new cleaning tape (clears the cleaning issue) and then try a brand new LTO2 tape.
If this works, then the issue was just related to your tapes, if this does not work then there must be a problem with he drive itself.
If the problem is with the drive, then contact www.tape-drive-repair.com for replacement costs. These drives are now very inexpensive and it might just be easier to replace the drive.
If you want to attempt to fix the issue yourself then respond back with a few more details and i will try and advise you on the best things to try.
Sep 07, 2012 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Insert backup tape, can hear it, then ejects, it doesn't matter which tape (two week cycle) - none will stay in drive. HP Ultrium 215 LTO 1
Sounds like a lost leader. When the tape is loaded there is a leader in the tape drive that hooks onto the end of the tape and pulls it out and onto the take up reel. If the leader gets out of position then the drive fails to load the tape and it is ejected. To fix it requires taking the drive apart. This might be a good time to upgrade to a newer model LTO. They were redesigned to eliminate this problem.
Jan 10, 2011 | HP StorageWorks Ultrium 215 LTO 1 Tape...
LTO Ultrium 4 Drive/Lecteurs stuck in it
Check that 'Prevent Media Removal' is disabled
Check the Support Ticket Device Analysis for indications of a stuck tape
Run the L&TT*** "LTO Stuck Tape Test"
Try a normal eject operation--Make sure that you allow up to 10 minutes for completion
Perform an Emergency Unload
Reset the drive to reset the drive firmware
Use Library and Tape Tools (L&TT) to Upgrade your Firmware
***Download LTT from www.hp.com/support/tapetools
Jul 29, 2010 | HP StorageWorks Ultrium 960 Ultrium Tape...
The tape will not eject from Tandberg LTO Ultrium 2, any ideas please?
look closely on the tray,, u'll find a pin hole in it,,, just enter the saftey pin, and it will edject
Mar 23, 2010 | Tandberg Data Tandberg LTO Ultrium 2 Tape...
HP StorageWorks ESL712e Ultrium (AA934B) LTO 2 Tape Drive Logo
4,273 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
