Question about Blaupunkt Cancun CR63
Blaupunkt cancun cr63 car radio
Radio worked fine- then battery died (had nothing to do with radio). when i jumped the car- the radio went "haywire" the radio now comes in on a random station and instead of "am" "fm" mode it comes up with "vf" signal. i cannot hear the station that does come in. when i press the volume up/down the radio freezes. it also freezes when i get to the balance/fade selections. i reviewed the manual online but there is no trouble shooting. i have done nothing
  • country1370 Aug 18, 2007
    yes i forgot to mention that i had the cd mode coming up also. when you say fuse- do you mean in the car/van or the fuse somewhere in the radio? i am not to wise at these things,
    but i do love to try to figure them out. I also love music.
    if you give me hint on that fuse i will look into that too. hopefully with 2 of us working on it- we can fix them.
    Thank you :)
I'm having the exact same symptoms and have had the same luck online. My guess is that the logic got fried during the "brown out" while trying to crank the engine on a very low battery. I thought I might find something about the "VF" and "SK" modes that it is getting into (pretty cool if I weren't missing my radio stations). I'm guessing they are European bands or something. Also getting into a CD changer mode - funny since this was a pretty low-end cassette tape model. My Cancun is 12 years old. What I'm going to try (when it stops raining) is to disconnect the battery leads for 15 minutes or so and then reconnect to see if that clears out the radio memory (if I could easily identify the correct fuse, that would make the process much easier but, alas, I can't). Let me know if you have tried anything else and I'll let you know if my attempt works.
Posted on Aug 18, 2007
  • oldguy61 Aug 20, 2007
    FIXED IT!!! Tried the fuse thing (#10 in the in-car fuse box) but it did not work.
    However, I disconnected both sides of the battery for about 45 minutes and then re-connected. The rational mind of the radio came back!! I had to re-program all of the stations, but at least now I can listen to AM and FM.
    I'll bet the same will work for you!
    good luck!
SOURCE:
Car wont start without it being jumped.....tachometer...radio, nothing works
Might need a new battery. Thats what it sounds like it could be something else. I have a 98 subaru and i had the same problem and went and got a new battery and it worked fine. try the new battery and if that works good if not sorry.
Apr 16, 2014 | 1998 Subaru Legacy
My battery went flat, and I have charged it for a while now and it still does not want to switch on, what should I do? I have only had it for about a month and 2 weeks now
Disconnect from vehicle and connect again. If it does not work, it is dead. Jump starting dead vehicles can damage radios.
Dec 14, 2013 | Car Audio & Video
Renault megane 2005 dynamique this morning i went to open the car the card doesnt work as well as the car wont open withh the spare card either i got into the car with the metal key and there is nothing...
Sounds like your battery died on you. Have it checked at an auto parts store for free, also if jump starting the car works but it dies after removing the jumper cables the alternator is bad. Check the battery first as it only takes one bad cell to kill it. Most batteries are only good for a few years, longer if you're lucky. A battery can die on you with no warning sometimes.
Aug 12, 2013 | Cars & Trucks
Hi, i have a 1995 nissan altima , When I installed my new radio deck in my Nissan , it was working fine for an hour until I turned off the car. Once I turned the car back on, none of my gauges moved, my...
flat battery isnt a good sign
no driving power =engine check light on
battery terminals tight
got 12 volt everywhere its supposed to be
was old radio linked to security or immobilizer
recheck radio wiring
1995 96 Nissan Altima Car Stereo Wire Colors
Apr 21, 2017 | Cars & Trucks
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
Started up this morning fine went and did not start at all later.
remove and, clean your battery cable clamps then retighten and, test.
If your battery is too discharged "jump" it using jumper cables and, another car.
Apr 25, 2010 | 1996 Chrysler Cirrus
Is it my battery?
well this is what you should try ,,jump the car get it running
then when its warmed up take the positive lead of the battery
if the car stops the alternator is gone (thats what charges the battery) if the car runs its fine
and if u have put another new battery in it and the alternator is fine look for any broken wires earths or positives that could be making it drain so quick
and make sure your battery levels are full
hope this helps
Jul 02, 2008 | 2001 Mercury Cougar
Car Audio & Video Logo
390 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
