Microsoft Windows 2000 Server Logo
joaqi padilla Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
File error 65535
When im trying to right click on CMD to Run As Adminstrator.. this message pop up. File error 65535 help me with this plsss..... maybe because of this Rundll32 system corrupt??? help me with this plsss plss
Anonymous
Level 3:
  • Master 412 Answers
  • Posted on Mar 18, 2009
Anonymous
Master
Level 3:
Answers
412
Questions
Helped
271777
Points
1322
Sounds like you have some corrupt windows files. I think you may also have a black logon screen and problems running programs as an administrator.
To solve this issue, first, boot your computer in Safe Mode. Do this by pressing F8 before the Windows Logo shows up during boot-up. Then, run Command Prompt as an Administrator (found under Start Menu > All Programs > Accessories - right click and select Run as administrator). Then all you have to do is type this:
sfc /scannow
(Space in between sfc and the /)
Then press Enter and the computer will fix itself. This is called the System File Checker Tool and it checks all Windows files for any corrupt or missing ones.
Hope this helps...
Good Luck!!
2answers
Printer error 0x60
If you're seeing this in the computer, most likely you need to reinstall the printer driver.
Epson b310dn error code 0x60
Fix Epson Printer Error Codes 0x60 by Epson Support
Step1: Remove the program which has recently been installed:
§Go to the "Control Panel" and then choose the "Uninstall a program" option
§Right-click on the software which you wish to uninstall and then click on the "Uninstall" button. It is always advised to mention that the SmartPCFixer has the un-installation function which will further save user's time by fixing errors smoothly.
Step2: Check for various updates available for Windows system.
§Click the "Start" button and then type the Windows update message in the search box. Hit the "check for update" option.
Step3: Run the SFC tool
§To resolve the Epson printer error 0x60, System File Checker tool is essential to include with the Windows system as it allows users to conduct a deep scan process by restoring all the corrupted Windows system files.
§Click the "Start" option and type the "CMD" command in the search box. Right-click the "CMD" command and run the administrator account.
§At the command prompt section, simply type "sfc /scannow", and hit the "ENTER" button
Step4: Log on windows in Safe mode
§With the help of Networking tool, simply check whether this error still pops up in Windows or not?
§Click the "Start" option and then type the MSCONFIG message.
§Next, hit the Boot icon from the pop up dialog.
§Next, tick the Safe Boot option in the Boot section and then select the Network and Reboot the PC.
If You Still Need Any Help then Do Visit Us: Epson printer error codes 0x60
Dial Epson Printer Support Number Toll-Free To Gain Online Help:- +1-877-760-6111
I'm trying ti install skype on my computer and get an error code #1618 , I have an account set up and all that.
Please, first try to re-boot twice, more here:
http://www.installsite.org/pages/en/msifaq/error/1618.htm
If that does not work, then please try the below.
Please follow these steps:
* Copy Skype setup file to desktop and rename it SkypeSetup.exe
* Click Start
* Run
* type "cmd"
* enter
* type "cd desktop"
* enter
* type "SkypeSetup /log"
* enter
* Skype install will start with logging enabled
* Try to install it.
* Install created one text file to desktop please attach it to here
May 31, 2011 • Skype IM
2answers
The phone is not turning on. It tells me JUM error 153 reset. But when i hit reset nothing happpens.
Reinstall the OS and restore from the most recent backup you have...
Download the OS file to your PC then install it to your PC by double clicking the file you downloaded. (Vista users be sure to right click on the .exe file and select "Run As Adminstrator.")
2. Go to c:\program files\common files\research in motion\apploader and delete the vendor.xml file.
3. Plug in your BB to a usb port and double click on "Loader.exe." It's located in the same folder as the above vendor.xml file.
Don't disconnect your BB unless you get an error message, or you get a completed message. Some of the upgrade steps take a while, and it may appear to have stalled or stopped, but it has not. Be patient, and let the update load (30 - 45 minutes).
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3answers
There was a runtime error 339 on my pc. component 'MBPrgBar.ocx' or one of its dependencies not correctlt registered: a file is missing or invalid
1->download the file . google it.
2-> copy this file to system directory then type the following in run command
3->regsvr32.exe MBPrgBar.ocx
1helpful
2answers
Spooler service not working?
If its Xp Click on Start > Click on RUn
Type in CMD Click on Ok
Type in the command in there :
SC CONFIG SPOOLER DEPEND= RPCSS (Press enter)
Restart the computer
Again open the CMD type in:
NET STOP SPOOLER (Press Enter)
NET START SPOOLER (Press Enter)
Try to Print
Note : In case of VISTA type CMD in Start Search
Right Click on CMD Select Run as Administrator and follow the rest.
Regards Soumajit
NET STOP SPOOLER
1helpful
I cannot right click on CMD !! File system error 65535
If your running windows xp, put in the XP install disc, restart the computer, and boot from the disk.
There will be 2 options for a repair, you want the 2nd option. So continue on until you see the 2nd option and choose it. This will repair the Windows directory, your files/data/software will be fine.
Cannot connect to Netgear wireless router adminstrator page
Maybe that's not the correct IP address.
If you have Windows XP:
1. Click Start
2. Click Run
3. Type cmd and press enter
4. Type ipconfig and press enter
5. Look for your gateway address, that's the address to put into your address bar.
Vista:
1. Start
2. In "Start Search" type cmd
3. Right click cmd that appears on the top and click run as administrator.
5. Look for gateway address
2answers
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
