Question about Sony KP-46WT510 46" Rear Projection HDTV
Picture flicker My monitor has a problem with the picture. Lets say I'm watching ESPN, the top half of the screen would all of a sudden jump to CNN, while the audio continues to stay on ESPN. The top half of the screen's image is distorted, while the bottom half of the screen stays proportionate. I had this problem about 3 years ago when the unit was still under parts warrenty, I had to pay for the technician to come by and diagnose it. At the time he told me that it was the B Board that went bad, and a new one was needed. Has anyone had this problem before? Has anyone heard of what the B Board is?
    Genius:
  • 1,694 Answers
B board = Part # A-1302-209-A fix by substitution......
check price and availibility..............B is a sister board mounted
to the A board (signal)........................................T.
Posted on Dec 04, 2007
SOURCE:
Luxor lux0140001B/01 1 week old picture has top half with a grey see through screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Apr 12, 2014 | Televison & Video
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Watching espn hd, the picture cuts off on one side. How do I adjust this? The ESPN bug is well within the border in the right hand lower corner, but a chart that comes on perodically during play...
There's a resolution/aspect ratio you can adjust in the picture menu, or straight from the remote. Choose the size you want on ESPN that best fits the picture while watching it.
Jun 16, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Red words under the words
ptc or decosing coil is bed or notworking proper so u have replace it
Jan 10, 2009 | Mag Innovision InnoVision XJ 717 Monitor
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Screen flicker/jumping
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
Nov 18, 2007 | ViewSonic GA771 Monitor
Picture flickers
B board plugs in to A board (signal) part # A-1302-209-A...
Let me know.......................T.
Aug 14, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
